on a 92 ls what to i have to do to make it fit a 88 hf crx?
buy mounts, dent the drivers side frame rail for the altinator pulley, and i think you have to cut the tranny mount off the front crossmember, im not positive on the tranny mount, but i'll let you know on monday when mine goes in
Get a motor mount kit, if its a good kit you don't need to dent the inner fender/frame rail... may have to remove the front tranny mount but not the one on the x member
[Modified by zCivic, 11:01 AM 3/20/2003]
youre gonna wish you bought a 90-91, the 92 is obd I, so you'll have to convert the car to obd I. unless you want to use a crx si extended harness, and you'll also have to convert the car to MPFI instead of DPFI.
edit-
he will have to dent in the driver's side framerail even with a hasport kit. its to clear the alternator pulley. be sure of stuff before you post misinformation. denting in the framerail is even in the hasport directions.
[Modified by 22lbGS-R, 10:05 AM 3/20/2003]
edit-
Get a motor mount kit, if its a good kit you don't need to dent the inner fender/framerail... may have to remove the front tranny mount but not the one on the x member
HF's are already MPFI
-kev
-kev
edit- nevermind, i remember why i thought he would have to do an MPFI conversion. i thought the 88-89 HFs were DPFI and the 90-91 HFs were MPFI. so i guess i'm wrong about this? Is it the DX i'm thinking about?
[Modified by 22lbGS-R, 10:16 AM 3/20/2003]
well I know a cheep HCP kit didn't have and it fit fine never used a hasport kit its overpriced crap..... BTW the misinfo you have just givin what about it.....Motor may be OBD1 but can still use OBD0 PR4 ECU get your info also correct
[Modified by zCivic, 11:22 AM 3/20/2003]
-kev
don't mind me, i'm a blind retard..........
-kev
Yes.
edit- BTW, theres a big article in the new SCC about this exact swap. you might want to pick it up.
[Modified by 22lbGS-R, 10:54 AM 3/20/2003]
Jules Winnfield
Jun 18, 2004 09:17 PM
dutchman5
Feb 6, 2003 12:48 AM
