Big favor all, with 1.8l or 2.0l turbo charged motors please post dyno #'s
I have a guy that claims all turbos regardless of flow rate will produce the same hp #'s in the same displacement acura motor. I want to prove to him that say a t3/60-1 will generate more hp than a straight t3 @ 10 psi. So please all post your dyno #'s @ 10 psi or whatever psi you did the dyno at along with the size of your turbo, and if possible its flowrate @ whatever psi you dyno'd at. Thanks much
This is with a gsr motor, T4 60-1, FMU fuel setup, 10psi, pump gas, and a full 2.5 exhaust. The car just recently made 440whp on race fuel and 17psi.
got damn ITR206 that is some crazie *** ******* number for 8 lbs!!!! GOOD ****!! I guess high comp + turbo + tune = VERY POWERFUL =P
thats at the wheels.
the timing retard we have set is .75 degrees per lb of boost.
yea it seems to work nicely for me , BOOSTEDHYBRID is a great tuner.
actually we lowered the vtec and picked up a few more hp and cleaned up the TQ curve more. belive it or not . it might be hard to see there, becuase i didnt plot the tq graph, but its true .
243.2HP 190.2ft/lb torque at 9psi on a GSR with a straight T3.
SAFC
RC 370cc injectors
Vortech FMU
Comptech ESM
SAFC
RC 370cc injectors
Vortech FMU
Comptech ESM
at one point it sure did unfortunately
. Things were figured out and it's running fine now. Like i said, it just made 440whp this weekend
For some reason the guy still thinks that a t3 would make the same amount of hp as a t4/60-1 @ 10 psi, you guys agree?
Daym... I feel like a chump in this crowd... I haven't been back to the dyno to pull out some timing... still @ 1.5 deg per #
[Modified by hybridsol, 11:35 PM 3/20/2003]
Boostfed nice numbers.. wow
yes yes, it's low. blablabla. put your cat on and see how much power you put out
[IMG][Modified by Ruckus138, 1:17 AM 3/21/2003]
[Modified by Andrew 825SM, 2:03 AM 3/21/2003]
For some reason it seems like the dyno at Import Builders puts out lower horsepower/torque numbers.
Stock b18b
Drag III w/t04b turbo
10psi
Stock Cat
2.5" catback
Hondata
440's
220hp/193tq
My run @ importbuilders
stock b16a
JRSC 10psi
2.5" Header back, no Cat
AEM CAI
Hondata
440's
220hp/153tq
old set-up now with a friend
344whp at 8000rpm, forget the torque
330whp at 6200rpm on the graph
84.5mm ls block 9:5:1
850cc injectors, haltech e6k
ts04, 60-1
12psi on pump gas with a very, very conservative tune
old 1.8l set-up made 450whp at 18psi on 116octane
ts04, 60-1
