Big favor all, with 1.8l or 2.0l turbo charged motors please post dyno #'s
I have a guy that claims all turbos regardless of flow rate will produce the same hp #'s in the same displacement acura motor. I want to prove to him that say a t3/60-1 will generate more hp than a straight t3 @ 10 psi. So please all post your dyno #'s @ 10 psi or whatever psi you did the dyno at along with the size of your turbo, and if possible its flowrate @ whatever psi you dyno'd at. Thanks much https://honda-tech.com/forums/images/smilies/emwink.gif
Re: Big favor all, with 1.8l or 2.0l turbo charged motors please post dyno #'s (mwasnp)
http://www.elite-motorsport.com/inlinedyno.jpg
This is with a gsr motor, T4 60-1, FMU fuel setup, 10psi, pump gas, and a full 2.5 exhaust. The car just recently made 440whp on race fuel and 17psi. |
Re: Big favor all, with 1.8l or 2.0l turbo charged motors please post dyno #'s (autoEXturbo)
heres mine stock motor , pump gas, and 8psi
http://boosted-hybrid.com/graph1.gif |
Re: Big favor all, with 1.8l or 2.0l turbo charged motors please post dyno #'s (itr206)
got damn ITR206 that is some crazie ass fucking number for 8 lbs!!!! GOOD SHIT!! I guess high comp + turbo + tune = VERY POWERFUL =P
ITR206 - 295hp at the wheels or fly? Your timing is retarded by S200??
Re: Big favor all, with 1.8l or 2.0l turbo charged motors please post dyno #'s (swlabhot)
thats at the wheels.
the timing retard we have set is .75 degrees per lb of boost. yea it seems to work nicely for me , BOOSTEDHYBRID is a great tuner. |
looks like vtec is too low. But AWESOME #'s. https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif
Re: Big favor all, with 1.8l or 2.0l turbo charged motors please post dyno #'s (SuperTeg95)
Hell yea nice #'s guys! Thanks keep posting!
actually we lowered the vtec and picked up a few more hp and cleaned up the TQ curve more. belive it or not . it might be hard to see there, becuase i didnt plot the tq graph, but its true .
243.2HP 190.2ft/lb torque at 9psi on a GSR with a straight T3.
SAFC RC 370cc injectors Vortech FMU Comptech ESM |
Re: Big favor all, with 1.8l or 2.0l turbo charged motors please post dyno #'s (EG9turbo)
http://www.elite-motorsport.com/inlinedyno.jpg This is with a gsr motor, T4 60-1, FMU fuel setup, 10psi, pump gas, and a full 2.5 exhaust. The car just recently made 440whp on race fuel and 17psi. |
Re: Big favor all, with 1.8l or 2.0l turbo charged motors please post dyno #'s (Bryson)
at one point it sure did unfortunately https://honda-tech.com/forums/images...s/emthdown.gif . Things were figured out and it's running fine now. Like i said, it just made 440whp this weekend https://honda-tech.com/forums/images...es/emsmile.gif
For some reason the guy still thinks that a t3 would make the same amount of hp as a t4/60-1 @ 10 psi, you guys agree? https://honda-tech.com/forums/images/smilies/emwink.gif
For some reason the guy still thinks that a t3 would make the same amount of hp as a t4/60-1 @ 10 psi, you guys agree? https://honda-tech.com/forums/images/smilies/emwink.gif |
Re: Big favor all, with 1.8l or 2.0l turbo charged motors please post dyno #'s (prophet)
http://members.cox.net/94supratt/terrydyno3.jpg
Heres mine it's a 1.74 liter B16A, 84.5mm psitons, T3/60-1 Stage V turbine wheel with .82 A/R |
Re: Big favor all, with 1.8l or 2.0l turbo charged motors please post dyno #'s (Boostfed)
Daym... I feel like a chump in this crowd... I haven't been back to the dyno to pull out some timing... still @ 1.5 deg per #
http://home.earthlink.net/~tailwags/Dyno_1.jpg [Modified by hybridsol, 11:35 PM 3/20/2003] |
Re: Big favor all, with 1.8l or 2.0l turbo charged motors please post dyno #'s (hybridsol)
Boostfed nice numbers.. wow
Re: Big favor all, with 1.8l or 2.0l turbo charged motors please post dyno #'s (shortyz)
Boostfed nice numbers.. wow |
http://members.aol.com/ruckus138/dyno/dyno1.jpg
yes yes, it's low. blablabla. put your cat on and see how much power you put out https://honda-tech.com/forums/images...s/emsmilep.gif [IMG] [Modified by Ruckus138, 1:17 AM 3/21/2003] |
Re: Big favor all, with 1.8l or 2.0l turbo charged motors please post dyno #'s (Ruckus138)
http://members.aol.com/ruckus138/dyno/dyno1.jpg yes yes, it's low. blablabla. put your cat on and see how much power you put out https://honda-tech.com/forums/images...s/emsmilep.gif [IMG] [Modified by Ruckus138, 1:17 AM 3/21/2003] [Modified by Andrew 825SM, 2:03 AM 3/21/2003] |
Re: Big favor all, with 1.8l or 2.0l turbo charged motors please post dyno #'s (Andrew 825SM)
For some reason it seems like the dyno at Import Builders puts out lower horsepower/torque numbers. Stock b18b Drag III w/t04b turbo 10psi Stock Cat 2.5" catback Hondata 440's 220hp/193tq My run @ importbuilders stock b16a JRSC 10psi 2.5" Header back, no Cat AEM CAI Hondata 440's 220hp/153tq |
i made 426 whp with 81mm pistons and 62-1 turbo on a clayton dyno.
Re: Big favor all, with 1.8l or 2.0l turbo charged motors please post dyno #'s (ekb18c)
old set-up now with a friend
344whp at 8000rpm, forget the torque 330whp at 6200rpm on the graph 84.5mm ls block 9:5:1 850cc injectors, haltech e6k ts04, 60-1 12psi on pump gas with a very, very conservative tune old 1.8l set-up made 450whp at 18psi on 116octane |
