Injector Upgrade -DX
Old Mar 19, 2003 | 11:43 PM
Josho_17's Avatar
Default Injector Upgrade -DX
How many CC does the TWO stock fuel injectors on the DX flow? How much does the stock SI injectors flow too? If i could get it for free, would it be work replacing the two fuel injectors with larger ones to supply more fuel without having to do the MPFI swap?
Old Mar 20, 2003 | 02:12 AM
altoid's Avatar
Default Re: Injector Upgrade -DX (Josho_17)
no, waste of time if its stock. not to mention i think they're both 240cc and i don't think they'll bolt up.. but i could be wrong.
[Modified by altoid, 6:13 AM 3/20/2003]
Old Mar 20, 2003 | 02:32 AM
Josho_17's Avatar
Default Re: Injector Upgrade -DX (altoid)
what are the SI injectors, are they smaller since there is four of them?
Old Mar 20, 2003 | 02:56 AM
USDM 4G VTEC's Avatar
the MPFI and DPFI "injectors" arent the same
the DPFI are kinda of a electronic sensor pulsing fuel into a trotle body.. and the design are different from the MPFI wich has an injector itself to do the work....
basically they are different, perform different and arent intercheangeable
Old Mar 20, 2003 | 04:32 AM
xci_ed6's Avatar
Default Re: Injector Upgrade -DX (USDM 4G VTEC)
Actually the only major differeances between Dx and Si injectors are:
Dx-side feed Si-top feed
Dx-high imedence Si-low
The magor problem with upgrading the Dx injectors is finding side feed injectors that will fit.
A better idea would be to add injectors in the air intake tube.
-Dustin
Old Mar 20, 2003 | 05:09 AM
Josho_17's Avatar
Default Re: Injector Upgrade -DX (Autocratic_1st_Gen)
don't supose you'd know any that would fit?
Old Mar 20, 2003 | 03:07 PM
Josho_17's Avatar
anybody?
Old Mar 20, 2003 | 03:38 PM
Malgerus's Avatar
Just do an MPFI swap; don't bother.
Old Mar 20, 2003 | 04:50 PM
Josho_17's Avatar
Default Re: Injector Upgrade -DX (Mr. S)
the car is automatic, there is not an automatic SI to get an ECU from... not doing a ghetto auto to manual swap either
1995dx
Feb 6, 2009 12:57 PM
baked_beanz
May 25, 2005 01:56 PM
jester
Apr 19, 2005 05:40 AM
stangkilla
Aug 3, 2002 06:20 AM
sneakypete
Jul 24, 2001 11:48 AM
