Music cuts out....nuthin but bass comes through.
Old Mar 19, 2003 | 08:38 PM
IloveNewt's Avatar
Default Music cuts out....nuthin but bass comes through.
What is teh source of the problem when sometimes, the music just cuts off form the speakers, but only teh bass comes through?
I have an alpine amp to the speakers and a 12in polk in the back with a old sony HU.
Is HU the problem?
Old Mar 19, 2003 | 08:59 PM
JTCdudeman's Avatar
Master H Technician
Default Re: Music cuts out....nuthin but bass comes through. (MordecaiPSI)
Lets C... YES... The HU is the problem unless your speakers are powered by an external amp which it doesnt sound like it by your post... Its sounds like your internal stereo amp on the HU is shorting out and will go bad soon... I would replace the HU if possible... SONY tends to not do speakers good some reason for car stuff.. I think they only got a small division labeled car audio engineering school retards... Thats what its got to be right? They do everything else well, but my car wouldnt have SONY anything touch it unless I had a walkman in the car....
Old Mar 20, 2003 | 12:50 AM
vteg's Avatar
New User
I am assuming you have an amp. Check all the connections. Check the remote lead for shorts. Does it do it only while driving? Check the rcas also. If you have a good friend, try borrowing their amp for a little while to help you out in your diagnosis.
Old Mar 20, 2003 | 06:14 AM
koco's Avatar
Could it be the hi pass crossover? Need more info on the system components.
Old Mar 20, 2003 | 09:04 AM
JTCdudeman's Avatar
Master H Technician
Default Re: Music cuts out....nuthin but bass comes through. (vteg)
whoops my bad!
Old Mar 20, 2003 | 09:26 AM
Broman78's Avatar
Default Re: Music cuts out....nuthin but bass comes through. (JTCdudeman)
You may not be too far off saying it is the HU remember he is dealing with a Sony.
Old Mar 20, 2003 | 10:21 AM
JTCdudeman's Avatar
Master H Technician
Default Re: Music cuts out....nuthin but bass comes through. (Broman78)
ture on that... I would guess something is bad wrong somewhere.... One amp powering a sub and speakers, yet only the sub always works while speakers actually cut out... HMM... HU is still my best guess cause it may not be puttin HP signal through or it might be the AMPS crossover going...
Old Mar 20, 2003 | 06:54 PM
JOMO
Guest
Posts: n/a
my friend has some 6x9 explods powered by a fosgate punch, ver nice! installation is everything!
Old Mar 20, 2003 | 07:21 PM
philly-O's Avatar
Default Re: Music cuts out....nuthin but bass comes through. (JOMO)
if the subs and speakers are running off the same amp, i am assuming it is a 4 or 5 channel amp. otherwise if the speakers are running off of the headunit's power it is probably a bad speaker causing the problems. if a speaker shorts it's self out (being blown), it will put the deck into protection and only the rca's will give output.
Old Mar 21, 2003 | 09:30 AM
OC 335i's Avatar
my car wouldnt have SONY anything touch it unless I had a walkman in the car....my friend has some 6x9 explods powered by a fosgate punch, ver nice! installation is everything!
There's just so much better stuff than most of your SONY Car Audio products at the same price.
Old Mar 21, 2003 | 10:23 AM
rjr162's Avatar
i don't care what install you do, sony's will never have nice highs.. and I don't care much for the lows off of their speakers either. and for the price most places have the sony's for you could pick up a set of infinity's which I think sound ten times better
ROCsFinest
Audio / Security / Video
Aug 25, 2008 06:46 PM
MilanoCivic97
May 1, 2007 12:17 PM
JohnnyEF
Nov 26, 2006 12:04 PM
civicmark
12
Nov 10, 2002 11:25 PM
