Huge favor to ask, need pics....
Old Mar 19, 2003 | 08:31 PM
MaaseyRacer's Avatar
Default Huge favor to ask, need pics....
i need throtle body pics from an 88-91 si... I also need a pic from the hose that comes off the valve cover and goes into the intake. There is a second hose attached to that hose and i need to know where it goes... My MPFI swap has not been going well and it seems that none of the manifolds i have seen look like my manifold... i have been to honda twice and a third time is most likly in order...i just need to see a civic or crx si or even an HF engine bay and i should be able to finish, and get my car running... Thanks
-BTW i have an 89 civic DX 5sp...
Old Mar 19, 2003 | 10:52 PM
spun Vtec's Avatar
Default Re: Huge favor to ask, need pics.... (MaaseyRacer)
you can eliminate that pcv vlave by putting a breather on the part that the lower hose connect's to and that way you dont havta wory about it going bad ever agan
Old Mar 20, 2003 | 06:55 AM
Louie B.'s Avatar
those hoses aren't really attached, just run next to each other to transfer heat from one to the other, you can elininate that transfer tube and just run a hose from your valve cover to your intake the other line is a coolant line that if I remember right runs from your thermostat housing to the bottom of your throttle body. I'll go out and double check that today, and try to get some pics if I can.
Old Mar 20, 2003 | 07:58 AM
Default Re: Huge favor to ask, need pics.... (thumpu77)
if it runs from the thermostat housing to the bottom of the throtle body, what goes to the nipple next to injector #4????
Thanks.
Old Mar 20, 2003 | 10:01 AM
LoooseGSR's Avatar
just get some 1/4" fuel line hose, about 6-8 inches of it, stick that on there...that's what I did.
Old Mar 20, 2003 | 10:17 AM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
Thanks.
yes...one line runs from the intake to the valvecover--the other is coolant and runs from the small coolant line on the intake manifold to the TB. i believe that is what you mean by nipple next to injector #4.
Old Mar 20, 2003 | 02:28 PM
Default Re: Huge favor to ask, need pics.... (fastcrxsi90)
WOOOOOHOOOOO!!!!!!!!!!!!
I figured it out... i stopped a kid on the street today when i saw him getting out of his 4g hatch started talking to him asked him to pop his hood... He had a ZC in there and i traced his lines to find out that, the line next to injector #4 goes to the throtle body and the extra line goes right below inector #4 to the EACV sensor....
i am way stoked i order a longer hose from honda it should be here tomarrow... I am going to try and start see if any codes show up and leak some coolant on my floor....
Thank you all for you help.
whiskeypiss
Oct 14, 2007 09:34 AM
onah
May 15, 2007 12:16 PM
Rubixcu7
15
Jul 11, 2006 02:40 PM
nk2k2
May 5, 2006 02:47 PM
NorthstaR
Aug 31, 2005 06:10 PM
