Jun valvetrain w/Skunk2 stage 2 cams????
Old Mar 19, 2003 | 08:27 PM
J2turbo21's Avatar
Default Jun valvetrain w/Skunk2 stage 2 cams????
Ok i bought a head already built with jun valve springs and retainers.I was going to get some jun3 cams but i heard they are on back order and are 200bux more that the skunk2 cams.I also heard that the specs of both cams are almost identical.My question is will I have problems running skunk2 stage2 cams with my jun valvetrain?
I did a search but didnt really find my answer,most say run the the same valvetrain but thats not the answer im looking for.Thanks.Here are the specs of the head.
Port Flow B16A head
Port and polish
Ferrea Stainless Steel Valves
speical valve job done by Joe Allaniz
Jun valve springs
Jun retiners
mill 35 thousandth
All new exhaust valve seals
Open chamber to 84.5mm
[Modified by J2turbo21, 5:28 AM 3/20/2003]
Old Mar 20, 2003 | 09:48 PM
J2turbo21's Avatar
Default Re: Jun valvetrain w/Skunk2 stage 2 cams???? (J2turbo21)
Anyone?
Old Mar 20, 2003 | 09:59 PM
illi Adik's Avatar
Most tend to keep the same valvetrain and cams, I know I would just to avoid issues. I know some have had problems running mix and match set ups. An all motor junkie would prolly know better though, Im just a boosted fool. Good Luck though.
Old Mar 20, 2003 | 10:08 PM
advanracing62's Avatar
Default Re: Jun valvetrain w/Skunk2 stage 2 cams???? (Jackson4Door)
the specs are similar, and as usual it is reccommended to run the whole package. But, I would say it is going to be safer to run the SK2 II's on that head over Crower or some other brands.
Old Mar 20, 2003 | 10:56 PM
Mr Hybrid's Avatar
Default Re: Jun valvetrain w/Skunk2 stage 2 cams???? (advanracing62)
Everyone says "run x cams with x valve springs, yada yada". The reason why people say that is cause supposedly if something goes wrong, then the company will back you up. Thats not true. There are too many variables involved with installing cams and valvesprings.
And i'm sure jun designs their valvesprings specific for jun cams because the jun 3's are notorious for snapping even with jun valvesprings.
I say get toda if you have the money or portflow makes good products too.
Old Mar 21, 2003 | 01:42 AM
evo's Avatar
evo
New User
Default Re: Jun valvetrain w/Skunk2 stage 2 cams???? (Teggie)
Who has own the longest lasting JUN cams??
how many miles and how long, I'm curious???
Old Mar 21, 2003 | 01:48 AM
J2turbo21's Avatar
Default Re: Jun valvetrain w/Skunk2 stage 2 cams???? (evo)
I beleive the honors go out to al bundy with 30,000+miles i think.Al come on down
Old Mar 21, 2003 | 10:27 AM
Al Bundy's Avatar
Right now, my car has 72,000 miles. I installed my jun cams with jun valvesprings and crower titanium retainers when I had 29,000 miles. So I currently have about 43,000 miles on them with no issues.
Oh yea the head ported and milled .0020 over
[Modified by Al Bundy, 11:29 AM 3/21/2003]
Old Mar 21, 2003 | 11:14 AM
do you know what you're talking about? I think most of what you are saying is a culmination of Honda-Tech opinions. How many JUN cams have you personally seen break? How many people do you KNOW that had JUN cams break, that were using JUN valvetrain?
Old Mar 21, 2003 | 11:36 AM
sgT's Avatar
sgT
JUN cams break because people use them with JUN springs. JUN springs like
to bind which is why you must be precise when installing them. No plug and play
stuff here.
canuck-mx6
Aug 1, 2004 06:24 PM
AllMoToRB18c
Mar 19, 2004 06:07 AM
chinners10
Apr 24, 2003 08:38 PM
JDMvtecDRAGSTA
Jul 22, 2002 01:21 AM
Thrashin
Jun 26, 2002 07:33 AM
