stalling after startup
Old Mar 19, 2003 | 07:53 PM
Lazydsm's Avatar
Default stalling after startup
Right after I start my car it idles lower than it should (500-700 rpms while cold). When I hit the gas there is a serious loss of power. When I take my foot off the gas and the rpms drop, my car almost stalls. It sputters the whole time. This lasts for about 10-30 seconds after every startup. Then the idle shoots up to normal and the car drives fine. Usually this doesn't happen when car has warmed up completely and started soon after its shut off.
I also get no more than 25 mpg on the highway and I drive a stock del sol s. I have changed the spark plugs/wire, fuel filter, o2 sensor, pcv valve, and distributor cap/rotor since this has been happening. Does this all make sense? I am totally clueless as to whats wrong.
Old Mar 19, 2003 | 08:00 PM
Turbo Powa's Avatar
Default Re: stalling after startup (Lazydsm)
I had a similar problem. Try replacing your IACV.
Old Mar 19, 2003 | 08:15 PM
Lazydsm's Avatar
Cool, i'll check it out. I didn't know if that would be it because i haven't heard of a problem like this caused by it. Did you have a problem with horrible gas mileage too? Or would this be a seperate problem?
Old Mar 20, 2003 | 06:33 AM
Turbo Powa's Avatar
Yea at the moment my IACV is not properly functioning. I also have horrible gas mileage. Hopefully when I replace it this weekend everything will be fine.
Old Mar 20, 2003 | 08:00 AM
88_SC_CRX_Si's Avatar
New User
When was the last time the plug wires were changed, the timing checked and cam/crankshaft pully alignment...
"Sorta" sounds like something may be a little too retarded or starting to fail....
Old Mar 20, 2003 | 08:50 PM
Lazydsm's Avatar
What does the IACV look like? I'm not exactly sure. And to test it do I just pull the connector on it and see if the idle drops?
Old Mar 21, 2003 | 08:29 AM
Turbo Powa's Avatar
follow these instructoions....
https://honda-tech.com/zerothread?id=447925
freeze580
Dec 29, 2013 08:53 PM
TruEM1
Dec 10, 2013 08:52 PM
ImportHatch
Dec 31, 2009 09:52 AM
myRice
Nov 20, 2005 11:45 AM
