need help! i want beat a gsr and b20/vtec with a ls
Old Mar 19, 2003 | 04:27 PM
willywood16's Avatar
Default need help! i want beat a gsr and b20/vtec with a ls
well i have a 97 integra ls and i have the basic bolt ons like header and aem cold air and i have exhaust. i was thinking about going ls/vtec and still might be a possibility if i can find a cheap b16 head. but i wanted to know from people who have gone all motor on a ls what do do so i can make this possible. ? i have searched this topic so please give advice on all motor build up of a ls
Old Mar 19, 2003 | 04:50 PM
hi mom's Avatar
Default Re: need help! i want beat a gsr and b20/vtec with a ls (willywood16)
If you run the v-tech swap from the LS.. you'll smoke most GSR's.. easily!
Just the v-tech conversion w/out your Intake, Exhaust and stuff, will be neck to neck with a GSR..
Im thinking about it aswell...I just finished my suspension and everything, so Im saving for the conversion! your lucky though, Im from Canada...so my swap is gona be like 3000..
2000 for the head
and another 1000 for the install..
Old Mar 19, 2003 | 04:52 PM
DK4200's Avatar
Get Unorthodox Racing Underdrive pullies. I have a 98 LS with all 3 Pullies and they are WELL WORTH THE MONEY. I got them for 300.00 shipped through Summit Racing. I love them. Im not sure how well they work on a v-tec motor but on my B18B they are great, i wish i bought them sooner
http://www.daveh81.homestead.com/honda.html
Old Mar 19, 2003 | 04:53 PM
ILOVEGIRLS's Avatar
Default Re: need help! i want beat a gsr and b20/vtec with a ls (95Solo1Tegra)
wow. 2000 for a gsr head and 1000 to install? thats so much.
i got my head for 1000 and 400 to installed including head gasket.
Old Mar 19, 2003 | 05:03 PM
hi mom's Avatar
Default Re: need help! i want beat a gsr and b20/vtec with a ls (ILOVEGIRLS)
Im from Canada, so my prices are twice the amount of yours..
hmm like.. the head is 2000.. whicih means you pay about 1000 .. and my install is 1000...so you pay 500...
Old Mar 19, 2003 | 05:08 PM
WiggiE's Avatar
New User
Easiest way to get close is cams, then go from there.
Old Mar 19, 2003 | 05:15 PM
hi mom's Avatar
Default Re: need help! i want beat a gsr and b20/vtec with a ls (WiggiE)
You could do a v-tech swap..
or you could do, cams, pulleys.. fuel rails, etc etc..
Its all what you want to do though, one your done those your practly **** out of luck and youde be stuck..
Get the swap, then get those minor things
Old Mar 19, 2003 | 05:17 PM
Mark's Avatar
*Bounty Hunter*
I thought stock fuel rail is good enough?
Stock fuel rails
LS V-tec would be dope tho
Old Mar 19, 2003 | 05:18 PM
thanks guys i guess ls/vtec it is for now unless i hear something better
Old Mar 19, 2003 | 05:25 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Get:
B20z block (keep your LS head)
Ported and polished head
Skunk2 mani
Crower 404 cams
S-AFC
Camgears
CAI
JDM 4-1
exhaust
Tuning
Have fun
Old Mar 19, 2003 | 05:32 PM
Default Re: need help! i want beat a gsr and b20/vtec with a ls (FrostyDC4)
you think that will be able to beat a b20/vtec and a gsr?
Old Mar 19, 2003 | 05:58 PM
sPaRk'iT's Avatar
Default Re: need help! i want beat a gsr and b20/vtec with a ls (DK4200)
[ You could do a v-tech swap..
Get the swap, then get those minor things ]
yeah a Ls-vtech.....sure why not....i rather do a Ls-vtec...its better!
[Modified by sPaRk'iT, 2:59 AM 3/20/2003]
[Modified by sPaRk'iT, 3:00 AM 3/20/2003]
Old Mar 19, 2003 | 06:01 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Default Re: need help! i want beat a gsr and b20/vtec with a ls (sPaRk'iT)
Dont forget a B16 tranny
Old Mar 19, 2003 | 07:48 PM
CLvtecGSR98's Avatar
your gonna need some luck....lol... But seriously, you are going to need some serious mods to an ls/vtec which would be your best chance. Ive yet to see anybody come close to my b20.
Old Mar 19, 2003 | 09:02 PM
Calavera's Avatar
Default Re: need help! i want beat a gsr and b20/vtec with a ls (CLvtecGSR98)
how much are you willing to spend?
Old Mar 19, 2003 | 09:08 PM
neo1z's Avatar
Default Re: need help! i want beat a gsr and b20/vtec with a ls (Calavera)
its vtec...i dont wanna be that guy...you know the "its vtec and not v-tech or v-tec" guy...but i have to be.
its vtec...not vtech or v-tec...etc...
Old Mar 19, 2003 | 09:13 PM
:jdmshmaydm:'s Avatar
Yeah. If you have a car with VTEC, pop your friggin hood for once!
Ls-vtec is better than Ls-vtec h ?
drumking15's Avatar
forget the ls/vtec idea unless you want to do it right imo! Now a b20 block w/ your head all done up and some semi-wild cams would beat a gsr, but no way would it take a b20/vtec, cummon 2 liters tuned will easily have 200+ at the wheels. What you should do is save up some change and slap a turbo on that bad boy...Ls's are prime for turbos. Do some research, but unless your ready to make your car gain only 20hp at the wheels with a ls/vtec setup then your going nowhere...and that 20 is gained from putting higher comp pistons like a ctr and some decent cams and all the i/h/e to boot. Im my opinion a good ls/vtec is in the upwards of 4 grand
head, rebuild bottom end w/ all new bearings, shot peen your rods, fresh rings w/ new jdm ctr pistons or a little less agressive jdm itr pistons, some jdm itr cams or even better ctr cams, a skunk2 mani, and some basic tuning tools such as fpr, vtec controller, and cam gears. Then youll be able to beat a gsr, but no way will you take a properply built b20...IMO b20's are untouchable unless your boosted or sleeve a b18 to 84+ mm's. Laterz
[Modified by drumking15, 6:14 AM 3/20/2003]
Old Mar 19, 2003 | 09:25 PM
SiR-DC2's Avatar
Only if you NEVER plan to run faster than 110 mph...after that a GSR would still walk the LS setup due to LS redline and B16A gearing.
Old Mar 19, 2003 | 11:42 PM
If you're going to do an LS/VTEC conversion, you're going to use all aftermarket/upgraded parts right? Well, you figure it wouldn't be fair running a "built" LS/VTEC against a GS-R with stock internals and stock everything. But, if you're all about going after stock GS-R's with a fairly built motor then go right on ahead.
Old Mar 20, 2003 | 06:35 AM
Xscream's Avatar
Default Re: need help! i want beat a gsr and b20/vtec with a ls (Gatecrasher19AF)
Simple just turbo
Old Mar 20, 2003 | 07:13 AM
E-Rok's Avatar
EPIC TUNING
Default Re: need help! i want beat a gsr and b20/vtec with a ls (Xscream)
gut the car, I ran 15.4 with a semi-gutted interior with POS 14" tires and a 2.7 60', now that I have I/E/test pipe it will run with a GSR with an intake and exhaust. But my car is a freak everyone says so it might not help you out
Old Mar 20, 2003 | 11:19 AM
startroops's Avatar
Default Re: need help! i want beat a gsr and b20/vtec with a ls (rewsnaeht)
If you ask me 5 months ago, I'd say LS/VTEC for sure.... now that I have chosen that path, I can tell you unless you have loads on money on your hand, don't do it. If you have the LS, follow the setup mentioned above:
Skunk2 mani (not necessary)
Crower 404 cams
S-AFC
Camgears
CAI
JDM 4-1
exhaust
Tuning
B16A tranny
+ either the B16A pistons or the USDM ITR (lower in CR than the B16A)
And you should have a pretty decent ride. My friend has a setup like that, a G2 RS and his car is quick.... If you go to http://www.g2ic.com lots of people are modding their B18A motors.
Old Mar 20, 2003 | 11:21 AM
startroops's Avatar
Default Re: need help! i want beat a gsr and b20/vtec with a ls (startroops)
PS. If you want to beat a CRVTEC with the LS..... good luck, you are going to need lots of it.
Also forgot to mention above, get a chip for your ECU that enables you to raise your redline in order to fully utilize the cams and tranny.
Old Mar 24, 2003 | 11:06 PM
ILOVEGIRLS's Avatar
when doing a b20 vtec..do u guys use the b20 fuel rail?
cmurda11
Feb 8, 2005 12:55 PM
nyteflyte2003
Dec 6, 2004 11:09 AM
kbplaya
Apr 21, 2004 12:28 PM
Gimpo
Apr 12, 2004 09:48 PM
Ignitecivic
Apr 24, 2003 09:39 PM
