zc, pm6 vs pg7
The pg7 ecu i bought for my zc was fried so i am useing my si's pm6 and my zc is running real strong. So i was wondering how big of a diffrence a pg7 ecu has on a zc? (if any of u guys have used both) I am still planing on getting a new pg7 or pm7. i just want to knwo if u can feel a significant change in performence?
Guest
Posts: n/a
this is what i've used in the past 3 years on my ZC...from worst to best in my opinion.
PM6 (90 Civic Si computer)
ZC programmed Zdyne (TRASH!)
PG7 (89 Integra)
the PM6 worked fine, but when i "upgraded" to the Zdyne ZC conversion ecu, it was a bit peppier and felt a bit faster, but it fucked my ignitor and timing up big time. EVERY time i got on it, with that ecu, the tach needle would do a little dance. then i plugged the PG7 in, and it instantly ran the engine a whole lot better. runs strong to 7500 with no tach fluctuation whatsoever.
so maybe the real ZC ecus perform best, but that Zdyne ZC ecu sucked like a fat bitch.
PG7 (89 Integra)
Guest
Posts: n/a
what to you have done to the motor depending if you have alot done the 90-91 teg ecu (pr4) might be better for what your doing
go outside and stare at your teg tailights.
I compared some of the different tunes between ECU's. To get an idea on what is/was going on...
You can find them here, just scroll down a little bit. However they are in EXCEL format tho...
http://geocities.com/chipman_13/ecu.html
Outsane
15
Feb 25, 2003 10:01 AM
