Running power wire in a 91 accord?
Old Jun 13, 2001 | 12:01 AM
TeG cRaZy's Avatar
Default Running power wire in a 91 accord?
I cant seem to find a rubber grommet for me to put one in! Can someone help me! Where can i feed the power wire to the amp?! Any help would be appreciated! If there are any webpages, that would help also!
Old Jun 13, 2001 | 06:02 AM
Hamil's Avatar
New User
Default Re: Running power wire in a 91 accord? (TeG cRaZy)
Ussually you can pull up the plastic thingy where the door closes on the floorboard. It's a good start.
Old Jun 13, 2001 | 09:53 PM
TeG cRaZy's Avatar
Default Re: Running power wire in a 91 accord? (atshaccord)
did that... but u have to feed the wire thru the firewall first
Old Jun 14, 2001 | 07:38 PM
TeG cRaZy's Avatar
ttt
Old Jun 15, 2001 | 12:03 PM
AMCMan93's Avatar
There is a plastic/metal piece on the firewall to the left of the driver side wheel well (facing the firewall from outside car). It has two bolts on it that you can take off and either drill a hole in it or stick something in between the piece and the firewall so when you put it back on it won't crimp the wire.
Old Jun 15, 2001 | 12:08 PM
m0t0rhead's Avatar
I have a '97.
I ran the wire from my battery along the firewall to the driver's side.. and punched a hole in the rubber surround on the firewall and shoved it down through that... then down the back of my hood lever and underneath the door sills all the way to the back.
Worked like a charm.
Hope this helps.
Old Jun 16, 2001 | 01:21 AM
TeG cRaZy's Avatar
Default Re: Running power wire in a 91 accord? (Escobar)
I looked for a rubbber grommet and couldnt find one. I dont really want to punch a hole in my car so im looking for another way to feed the wire!
Old Jun 17, 2001 | 02:02 PM
dvsOasis's Avatar
well there are wires already that go through the firewall...see if u can fit your wire there too...and how can ur car not have a rubber grommet? i think i saw several in mine...i'll check again later
Old Jun 17, 2001 | 07:25 PM
TeG cRaZy's Avatar
Default Re: Running power wire in a 91 accord? (dvsOasis)
yeah theres one that i saw, and i tried to punch a hole with a clothes hanger.... but it wouldnt go...
datEM2
Honda Civic (2001 - 2005)
Apr 18, 2008 03:26 PM
stlucky22
Sep 3, 2007 06:01 PM
LSRracing95
Audio / Security / Video
Jul 17, 2006 11:02 PM
-1TSXer-
Jan 26, 2003 09:28 PM
