Clutch system lube points?
I have a squeak in my clutch pedal (at the bottom of the travel) that isn't present for the first 15-20 mins. of driving but then gets worse over the day. I replaced the cable, so it isn't the lube inside there. It must be a external point that needs some lube. I notice that when it rains I can drive it as much as I want and the squeak never surfaces. Based on this I assume the pedal assy itself isn't to blame, its more likely to be in the engine bay. Any idea where lube points for the clutch in the engine bay are?
Street Ghost
10
Sep 30, 2004 10:03 PM
