Prophets dyno # with our manifold and downpipe.
Old Mar 19, 2003 | 10:09 AM
Overblown-Teg's Avatar
Default Prophets dyno # with our manifold and downpipe.
This is on a stock gsr engine with 5.5psi of boost. Using a Hondata tuned by boosted-hybrid.
[Modified by Overblown-Teg, 7:10 PM 3/19/2003]
Old Mar 19, 2003 | 10:16 AM
FredoSP's Avatar
Default Re: Prophets dyno # with our manifold and downpipe. (Overblown-Teg)
very nice, im assuming u have a 3" exhuast ..can u please list your setup.
Old Mar 19, 2003 | 10:17 AM
prophet's Avatar
Default Re: Prophets dyno # with our manifold and downpipe. (FredoSP)
2.5 inch exhaust...3inch downpipe.
Old Mar 19, 2003 | 10:23 AM
Default Re: Prophets dyno # with our manifold and downpipe. (prophet)
Dennis that was fast.. There is a complete run down on the boosted hybrid site where the dyno graph is hosted. Check it out.
Old Mar 19, 2003 | 10:27 AM
prophet's Avatar
here's the link to jeff's site if u guys want the low down http://www.boosted-hybrid.com/dyno_video.html
this was done on 45 mins with the hondata unit..jeff definately gets a
todd also gets a
If anyone is near central pa or allentown i'd check out jeff (boostedhybrid) for tuning and todd (overblown-teg) for custom work. Both are awesome to work with and they make sure everything is done right before letting you go.
Old Mar 19, 2003 | 10:34 AM
underpressure02's Avatar
Hey todd I think you should have cuts prophets springs for him also. It looks like he is 4 wheeling. Manifold looks good and made some great power. His downpipe has some of my skin on from changing his oil the other night.
Old Mar 19, 2003 | 10:37 AM
prophet's Avatar
Default Re: Prophets dyno # with our manifold and downpipe. (underpressure02)
rofl...quit your bitching chad. My car already has tons of todd's blood on it
Old Mar 19, 2003 | 10:48 AM
Chad the 4x4 stance should make it easier to work on. I want him to get some brakes on it.. That thing is scary when you come up to a turn. I appreciate the complements. Thanks.
Old Mar 20, 2003 | 04:21 AM
So no one else thinks that those are decent numbers?
Old Mar 20, 2003 | 04:24 AM
PM-Performance's Avatar
i think they are bad *** numbers, the manifold is awesome .
He overbown, how much to make me a 3inch dp and maybe a 3inch exhaust too ? all mandrel mi assuming , or do you just weld the bedns with muliptle pieces rather thna bend?
let me know .
Old Mar 20, 2003 | 04:38 AM
alpha's Avatar
Very nice numbers Any videos
Old Mar 20, 2003 | 04:44 AM
Default Re: Prophets dyno # with our manifold and downpipe. (itr206)
I get mandrel bends a peice them together just like all the other guys do. For the exhaust I would get one of kteller8's kits to put on. having nice one piece bends like that is sweet. Are you venting your wastegate to atmosphere or do you want it plumbed back into the system? Should be around $350 for a 3" stainless downpipe with flex joint. If we go with ktellers kit and muffler I can get the exhaust on for around $450 total. Pm me if you want to do it.
Old Mar 20, 2003 | 06:02 AM
i have my wastegate open air .
wow i didnt think it ouwl be that much . ill let you knwo then . maybe ill hold off for now and see how my ecutout works for me
Old Mar 20, 2003 | 06:13 AM
You think $350 for a 3" dp is too much? And $450 for a full exhaust installed? Geoff sells the same down pipe for $450.. I can see if I can do it any cheaper. What setup do you have now?
Old Mar 20, 2003 | 06:41 AM
the reason i say that is becuase i can go get a maaxrev for that price. i was just assuming this would be cheaper. I got my 2.5 one made for $83, not fully mandrel though, but i think it might be restricting me a little beucase its small .
but to give you an idea this is what i have now . .. . **** weetodd is down
Old Mar 20, 2003 | 06:46 AM
prophet's Avatar
todd will take care of you. if anythign ever happens he can fix it for you on the spot...you won't have to ship that **** back to where ever. Stainless is the only way to go, and that's what jacks up the price along with the flex.
Old Mar 20, 2003 | 06:59 AM
Thanks Dennis. He is right though.. 3" stainless is not cheap. I could do it in steel and save alot of money but that doesn't hold up nice. Does max rev make a full 3" or is it a 2.5" to 3"? I thought you couldn't fit a 3" on there with out severly hacking the angles. To have a chopped 3" it might be better flow wise to run the good 2.5". And the exhaust I was only charging $100 to fully weld up and mount the whole system.. I thought that was pretty decent. I mean I get $75 just to weld on two mufflers. Let me know then.
Old Mar 20, 2003 | 08:13 AM
SuperTeg95's Avatar
I see an AEM intake(w/bypass valvle on the civic). Nice custom intercooler piping.
Old Mar 20, 2003 | 08:29 AM
aight ill let you know , im gonna try this ecutou 1st adn see if it does the trick for me for now .
Old Mar 20, 2003 | 09:59 AM
Joseph Davis's Avatar
Never met boosted-hybrid, but I've known Todd for a couple years now. Definitely one of the nicest people I've ever met, and handy with a TIG machine to boot.
Old Mar 20, 2003 | 10:01 AM
Smashback's Avatar
That rocks the house for almost no boost! The manifold is overkill for that little boost, but I'm sure it will be cranked up soon and put to better use
Old Mar 20, 2003 | 10:20 AM
Default Re: Prophets dyno # with our manifold and downpipe. (Hatchblack)
One thing to mention. With a t3/60-1 turbo he is reaching full boost under 4k rpm.. I thought it was good. Not sure if the manifold design is responsible or if its precisions great turbos
well see thats the thing , thtas prob why hes makign that power becuase of the manfild design and im sure the dp doesnt hurt
Old Mar 20, 2003 | 10:33 AM
Smashback's Avatar
Well, it might help but I doubt that just getting an extreme tubular manifold is going to make that much difference at 5 psi.
At such a low boost level there's not going to be much "resistance" in the manifold.
But of course, it could be the fact that he's running a monster turbo and you'll never see 25x whp at 5 psi out of a t3/t04e
edit: just to make sure, i am not bagging on it, but i don't think the manifold will live up to it's full potential until the boost is really turned up, then it can be compared to other manifolds at a high level of boost!
[Modified by Hatchblack, 7:36 PM 3/20/2003]
Old Mar 20, 2003 | 10:39 AM
LSiTurbo's Avatar
Waht kind of Mani. is that? it looks like a full race. nice set up and nice #s too!!!!
