kill switch from engine ground?
I dont know about this, like I'd think if you extended the ground wire any it wouldnt be good for the engine. I might just be speaking from out of my *** though so you know.
I was just wondering if anyone else had done it also? Results?
If you use it off the ground, you might blow a fuse each time you turn the switch back on. My friend tried to set up an ECU reset switch but kept blowing the 7.5amp back-up fuse every time he turned the switch off then on again.
You would need one fat *** switch to handle the current that can run through the main ground cable. Plus, if the switch has to be inside the cabin, you would need to severely up the wire gauge to compensate for the extra length. Bad idea all around.
641iowaguy641
Jun 19, 2013 01:53 PM
hatchinprogress
20
Aug 14, 2004 05:50 PM
sounds like a bad idea then.
