Check engine light after 160kmh???
Old Mar 19, 2003 | 01:34 AM
bokguay's Avatar
Default Check engine light after 160 kph???
Once i pass 160 kph i always get a check engine light and the car starts shaking...the code is #7 which is the tps sensor...after i restart the car the light goes away....what could be cause this to happen only after i pass a certain speed?
[Modified by bokguay, 10:43 AM 3/19/2003]
Old Mar 19, 2003 | 01:44 AM
Lei Siew Long's Avatar
Default Re: Check engine light after 160kmh??? (bokguay)
well, if it is the TPS, it might be because the voltage isn't consistent and it is fluctuating. test the voltage. it should be .5v when the throttle is closed and 5v at WOT. if not, switch it out for another TPS.
Old Mar 19, 2003 | 01:52 AM
bokguay's Avatar
Default Re: Check engine light after 160kmh??? (Hatch4urSnatch)
yah the voltage is there...and its reading at the right voltage..soo i ono
Old Mar 19, 2003 | 02:06 AM
both at closed throttle and WOT?
did you check to see if it is throwing another code immediately after the 7 code?
Old Mar 19, 2003 | 10:11 AM
bokguay's Avatar
yah at closed throttle its areound .44 and at open throttle about 4.9...and there is no other code but the #7
Bostonbob
Apr 6, 2017 09:14 AM
Djmontiel
Feb 16, 2016 01:30 AM
CarnEvil
Jul 3, 2007 04:36 PM
joepiper5
Feb 25, 2005 03:52 AM
