jdmb16a1 swap problems/////HELP?
Old Mar 18, 2003 | 10:46 PM
89sib16's Avatar
Default jdmb16a1 swap problems/////HELP?
i have a jdm b16a1 ,..Do i have to convert to obd-1? My new motor came with a pr-3 cpu will the wiring guide from hasport work?? Wheree you run four new wires?
Basicaly what i want to know is if i can run my vtec,knock,o2,vtecoilP and plug in the pr-3 cpu and drive. i also need a rear bracket from an 89-91 SiR or 90-93 Integra, part number 50827-SK7-020. Anybody have one for sale??
[Modified by 89sib16, 2:53 AM 3/19/2003]
Old Mar 19, 2003 | 01:19 AM
Mr. B in Az's Avatar
From: Where the hell is Bullhead City, Arizona, U.S.A. Formerly of Huntington Beach, Ca 92649
Default Re: jdmb16a1 swap problems/////HELP? (89sib16)
Hey NOOBe!
try using the search function.
Old Mar 19, 2003 | 04:21 AM
Home Skillet's Avatar
Default Re: jdmb16a1 swap problems/////HELP? (Mr. B in Az)
Hey NOOBe!
Post count doesn't make him a noob. As I see it you're a noob, you've only been here 80 days and he's been here 100 days more than you. So what if he doesn't post a lot. If you have nothing constructive to say then don't post, NOOB
Old Mar 19, 2003 | 05:11 AM
EP3_05's Avatar
You don't need to convert to OBD-1 unless you have and OBD-1 ecu. From what it sounds like you have gotten a swap with an OBD0 PR3 ecu which means you will not nee to convert to OBD1 And you can follow hasports wiring for adding the 4 extra wires. Good Luck with the swap
Old Mar 19, 2003 | 06:10 AM
ScottEK's Avatar
Default Re: jdmb16a1 swap problems/////HELP? (91civic)
Just curious, how do you know he can just add the four wires when he never mentioned the model of his car.
Old Mar 19, 2003 | 06:20 AM
EP3_05's Avatar
Default Re: jdmb16a1 swap problems/////HELP? (beta13)
I assumed he had an Si by looking at his screen name but I guess I should have asked.....
Old Mar 19, 2003 | 06:56 AM
Phatwhippin_CRX's Avatar
umm...... yup.....
solder up the hasport harness to the correct ECU pins, then run the plugs the right plugs on the engine, and you're set....... just make sure you get that 90-93 teg bracket first
Old Mar 19, 2003 | 08:11 AM
slowpokesi's Avatar
Default Re: jdmb16a1 swap problems/////HELP? (Phatwhippin_CRX)
check my sig
Old Mar 19, 2003 | 09:25 AM
Default Re: jdmb16a1 swap problems/////HELP? (slowpokesi)
haha i had one first !!!
http://www.phatwhippinCRX.20m.com
Old Mar 19, 2003 | 10:31 AM
slowpokesi's Avatar
yah but i posted mine first, i actually used a little bit of yours when i did my swap a few months back, but i guess i thought there was something i can add, mine has pictures, a better wiring diagram and vacum diagram compared to yours.
Old Mar 19, 2003 | 10:35 AM
argh! you win! bastard!!! lol
i should really update my site.... haha
my Efin SI
Aug 12, 2009 09:48 PM
downsycrx
Sep 25, 2006 10:52 AM
Blazeone
Sep 20, 2004 07:08 PM
Mike banX
Jul 26, 2004 02:53 AM
KiD Fr0m Da 516
May 15, 2004 02:15 PM
