Help Me!!.....ABS Question????
Old Mar 18, 2003 | 07:40 PM
DanielLaruso's Avatar
Default Help Me!!.....ABS Question????
i started my car today and as soon as i shifted into second, the abs light came on...and stayed on. i turned the car off at the first light i came to and it came back on when i shifted or as soon as i started moving. when i got to my girls house, i lloked in the haynes manual and checked the code, which was 4-8, the book said that it was a SPEED SENSOR in the REAR LEFT.
my question is: where do i go from here?????
STUFF THAT MAY HELP: i recently did a swap---(auto to manual), last summer i replaced the rear brakes, and i have never had any problems until tonight.
Any help will be appriciated.
Old Mar 18, 2003 | 07:57 PM
blykins's Avatar
Banned
Default Re: Help Me!!.....ABS Question???? (DanielLaruso)
My ABS light comes on sometimes, i turn the car off and back on, and it goes away. I guess its some weird thing.
Old Mar 19, 2003 | 12:01 AM
JDMH22HATCH's Avatar
Default Re: Help Me!!.....ABS Question???? (blykins)
Your ABS sensor is easy to check. Take off your wheel and look on the back side of the hub. There will be two bolts holding a black cover and under that two more bolts holding the abs sensor. Make sure the abs ring is straight, because if it is loose or tilted, sometimes the sensor won't read right. Good luck.
Old Mar 19, 2003 | 01:52 PM
Default Re: Help Me!!.....ABS Question???? (JDMH22HATCH)
thanks........would that be the probable explanation? and what am i looking for when i get to it??
Old Mar 21, 2003 | 06:19 AM
up
need input...
Thelandlordsmm
Aug 3, 2009 07:30 PM
manuelesr
Apr 13, 2008 01:08 PM
IntegraLs94Cam
Mar 29, 2005 05:24 PM
93sleeper
Sep 23, 2004 08:22 PM
Dirt
May 22, 2002 12:38 PM
