How do you polish an intake manifold?
Old Mar 18, 2003 | 05:51 PM
Fuster_Cluck's Avatar
Default How do you polish an intake manifold?
Someone was saying I should polish the intake manifold of my GSR motor before dropping it into my Cx. Just wondering if this is necessary and if so, how's it done?
Thanks!
Old Mar 18, 2003 | 05:57 PM
crazykid's Avatar
Default Re: How do you polish an intake manifold? (Hybrid93Hatch)
inside or outside???
try...
www.theoldone.com
tehy have some articals about port matching and polishing i belive... check it out.
Old Mar 18, 2003 | 06:08 PM
joe_bocc's Avatar
I've been advised not to polish the IM after the fuel injectors. By doing this, the fuel from the air/fuel mixture begins to loose anitomization (sp?) which is not good for power. Can anyone back this up?
Old Mar 18, 2003 | 06:36 PM
BabyDaddy's Avatar
Default Re: How do you polish an intake manifold? (joe_bocc)
your right on your theory but no gas get's injected before the end of the manifold. the injectors are mounted in the intake mani. at the head but they are pointed straight into the intake port.
Old Mar 18, 2003 | 06:41 PM
BabyDaddy's Avatar
Default Re: How do you polish an intake manifold? (BabyDaddy)
oh and for the original question. you really don't need to go to all the trouble of polishing it. just get in there and smooth everything out (take the casting lines out, hit it with a cartridge roll and finish it with the sandblaster). Unless your experienced with porting, don't go trying to change the size or shape of any of the runners.
OEMwh0r3
Mar 11, 2010 01:37 PM
Rusty Shackleferd
Feb 20, 2006 02:39 PM
Mike1486
May 27, 2005 01:10 PM
E. Honda
Nov 18, 2002 05:40 PM
