problems starting 88 crx si
Old Mar 18, 2003 | 04:34 PM
Wiz's Avatar
Wiz
Default problems starting 88 crx si
I left the lights on so I figured I just needed a jump, jump didn't work, in fact 3 jumps didn't work
I replaced the starter today and had the battery recharged, started the car up, it cranked and started fine, I let it run a while, turned it off to get something from my room come back try to start it and presto no crank no nothing, could this be either a battery thats not holding a charge, bad connection or both
anyone dealt with something similiar to this?
Old Mar 18, 2003 | 04:43 PM
pokemon's Avatar
Default Re: problems starting 88 crx si (Wiz)
Alternator
Old Mar 18, 2003 | 05:18 PM
Buzz Kill's Avatar
Default Re: problems starting 88 crx si (pokemon)
Check to make sure you are getting a good ground, The ground wire runs from the battery down to the unibody then on to the transmission and a 10mm bolt there. If that connection is corroded, car no start!
Also be sure that the wire from the valve cover to the area above the head light is also present with good connections.
To fix a corrosion problem, use some sand paper to freshen the contact points and coat with a lite coat of grease.
Old Mar 18, 2003 | 07:16 PM
Shawn C's Avatar
In The Garage
Alternator
probably not. if the alternator was bad, the car would slowly die as it ran (battery would die and not get charged) my guess is the battery. test it with a load tester. it should register about 12.6x volts and, when loaded, not drop below 10 volts. I'm thinking that, since you deep-cycled your battery (totally drained it), then it is ka-put.
Old Mar 18, 2003 | 08:02 PM
Wiz's Avatar
Wiz
Default Re: problems starting 88 crx si (22lbGS-R)
$#@$($@# ground $%#@$@$@
thanks for the input, I had a friend come by to take a look at it aswell
friend being late - slap on wrist
being electrocuted - priceless
for everything else there's mastercard
okiecrxhf
Oct 18, 2012 08:18 PM
troyaj2
Feb 22, 2010 07:11 PM
1993gsrcivic
Dec 2, 2008 10:30 AM
9 CRX si 1
Nov 5, 2006 03:36 PM
acmeotally
Nov 7, 2005 10:57 PM
