Help me my car wont start!!!!
Old Mar 18, 2003 | 03:56 PM
CRXMATT's Avatar
Default Help me my car wont start!!!!
I am not sure what is wrong, I shot some gas into the intake and it started, I think that it is either the fuel pump or the main relay. help...
Old Mar 18, 2003 | 04:00 PM
wickedEFguy's Avatar
Default Re: Help me my car wont start!!!! (CRXMATT)
have you checked your codes? Check all connections and see if you are getting any fuel pressure, something you can try is pull your fuel rail and injectors off and have someone hold them and try cranking over the engine and see if they squit or not.
Old Mar 20, 2003 | 12:57 PM
CRXMATT's Avatar
I am not getting any fuel pressure, it does not even sound like my fuel pump is coming on......is there a reley that controls the fuel pump???
Old Mar 20, 2003 | 01:32 PM
wanttorace's Avatar
there is a fuel pump fuse see if its blown
Old Mar 20, 2003 | 04:57 PM
spooledex's Avatar
check if you are getting power to the fuel pump under the seat
Old Mar 20, 2003 | 06:01 PM
jeimport's Avatar
Default Re: Help me my car wont start!!!! (spooledex)
It is your main relay for sure. It is located directly above your hood release latch. You can get em from junk yards for cheap, or buy a new one from honda for like $45. It will probably start up after an hour or so, unless it went totally bad.
dgonzals's Avatar
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
check engine light on....if so, codes? might help a little more....for the 2nd time....
jerryscherry
13
May 8, 2014 10:08 PM
iNDyCRX
Apr 24, 2008 12:54 PM
nicko360
15
Jan 17, 2007 06:22 PM
whitehf
Aug 6, 2006 01:22 PM
JDMlyfestyle
25
Oct 16, 2004 11:05 AM
