Dust boot on strut with Skunk2 coilovers
Old Mar 18, 2003 | 11:46 AM
1hotintegra's Avatar
Default Dust boot on strut with Skunk2 coilovers
the oem dust boots will not fit with the skunk2 coilovers i have. i just got tokico whites... i dont wana run with no dust boot so what could i do??
Old Mar 18, 2003 | 12:02 PM
jonsteR's Avatar
Default Re: Dust boot on strut with Skunk2 coilovers (1hotintegra)
user power sterring boots.
old pic...
Old Mar 18, 2003 | 12:34 PM
Default Re: Dust boot on strut with Skunk2 coilovers (jonsteR)
where do they connect to the top?? how much are they?
Old Mar 18, 2003 | 12:51 PM
VTECorona's Avatar
Is it possible to put them on without taking out the strut? Please say yes.
Old Mar 18, 2003 | 12:56 PM
tegasaurus's Avatar
Default Re: Dust boot on strut with Skunk2 coilovers (97RedTegGSR)
you would have to cut the boot vertically, slip it around, then re-seal the cut with an apoxy of some sort. That is how some cheap mechanic shops put on CV boots so im sure it will still apply to shocks.
-ryan
Old Mar 18, 2003 | 01:04 PM
TurbothisLS's Avatar
Default Re: Dust boot on strut with Skunk2 coilovers (tegasaurus)
-ryan
seriously?
that's messed up
i would be pissed if that happened to me
Old Mar 18, 2003 | 02:24 PM
spd18's Avatar
Default Re: Dust boot on strut with Skunk2 coilovers (TurbothisLS)
i just installed my ground controls and koni yellows this past weekend. i couldnt figure out how to make the stock dust boots fit (like in GC's instructions), so i called GC and they told me just not to put it on.. so i didnt. <shrug>
Old Mar 18, 2003 | 03:14 PM
jonsteR's Avatar
I just zip tied them to the bumpstop (top) and the shock body (bottom). They're about 11 bucks each from when i bought it. I got them through autozone. HTH
Old Mar 18, 2003 | 03:24 PM
jeebusm3's Avatar
Default Re: Dust boot on strut with Skunk2 coilovers (spd18)
In the GC instructionsl it says to cut the stock covers to fit. You can probably to the same for the skunks.
Old Mar 19, 2003 | 04:05 AM
Default Re: Dust boot on strut with Skunk2 coilovers (gtravsr)
if you cut em then they wont cover the whole shaft of the strut and it would be pointless
Old Mar 19, 2003 | 05:26 AM
jeebusm3's Avatar
i firgured that but i cut them anyway. i wonder what it's doing to my shocks?
Old Mar 19, 2003 | 03:39 PM
spd18's Avatar
is it bad to not have any dust covers at all (like what i have, and what the GC told me to do)?
Old Mar 19, 2003 | 03:52 PM
lshobo's Avatar
the instructions i received from ground control said to cut off a portion of the boots, leaving only 1 1/2" which is apparently enough to cover just the bumpstop. you probably don't need them on, but i cut them on all fours anyhooo
Old Mar 19, 2003 | 04:11 PM
VTECorona's Avatar
Default Re: Dust boot on strut with Skunk2 coilovers (lshobo)
Arent the stock ones metal? I wouldnt want that shiz on my new stuff. I cant believe they actually expect you to re-use them..
Old Mar 15, 2004 | 11:40 AM
Duranged's Avatar
dust on the shocks really won't wear them out any faster. the main reason for the boots is to prevent dents and scratches on the piston rod. dents and scratches will wear the seals away allowing dust and dirt to get into the shock. so... cutting down the dust boot is still better than none at all because it will prevent some of the dents and scratches from happening. I personally left them off. I was too lazy.
Old Mar 15, 2004 | 01:33 PM
SIK IN DA HED's Avatar
New User
Default Re: Dust boot on strut with Skunk2 coilovers (Duranged)
just dont use the darn dust boots, man!
Old Mar 15, 2004 | 01:52 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Dust boot on strut with Skunk2 coilovers (SIK IN DA HED)
I would never daily drive the car w/o any covering over the shock pistons, especially if they are high dollar shocks like Konis. I would not use the stock metal dust covers at all, those power steering boots seems like the best option.
If you want to add them, just take the shocks off, it's very easy, especially if you are running coilover suspension.
Old Mar 15, 2004 | 02:13 PM
mamaboy's Avatar
ahhh. take the dust covers off...you'll be fine...just don't go off roading on them
Old Mar 28, 2004 | 07:43 PM
WalkmanX's Avatar
Default Re: Dust boot on strut with Skunk2 coilovers (mamaboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mamaboy &raquo;</TD></TR><TR><TD CLASS="quote">ahhh. take the dust covers off...you'll be fine...just don't go off roading on them</TD></TR></TABLE>
I'm in the same boat. The shop that did my rear shocks left the dust boot off w/o me knowing and I just took a trip to TN where I had to drive on dusty graval roads.
Is there anyway to examin the piston for damage when I go back to get them reinstalled? If they are I will be asking them for new shox
skunk2.com
Aug 1, 2012 08:18 AM
1hotintegra
Mar 15, 2004 11:32 AM
mattjcali22
Jan 22, 2004 11:31 PM
