Quaife/Carrier bearing install, how-to?
Old Mar 18, 2003 | 08:06 AM
b20guy's Avatar
Default Quaife/Carrier bearing install, how-to?
Can someone tell me how to do this without a press?
Old Mar 18, 2003 | 12:11 PM
vtecdeath's Avatar
Default Re: Quaife/Carrier bearing install, how-to? (b20guy)
not going to happen!
Old Mar 18, 2003 | 12:49 PM
CHEETAH's Avatar
goto plumbing shop like home depot get a 6" pipe with diameter of same size as inner ring on carrier bearing, bang it in with a sledge hammer ... dont bang the bearing in the soft shell casing only on the hard spot.... oil the insides before hammering in
Old Mar 18, 2003 | 01:07 PM
PupaScoopa's Avatar
Default Re: Quaife/Carrier bearing install, how-to? (CHEETAH)
That's pretty harsh...
See if you can find a machine shop that'll do it for ya cheap.
Old Mar 18, 2003 | 01:34 PM
CHEETAH's Avatar
Default Re: Quaife/Carrier bearing install, how-to? (PupaScoopa)
I do about 10 of them per week ...
Old Mar 19, 2003 | 04:29 AM
b20guy's Avatar
The guy who is going to install this for me says he doesn't need a press either. I was curious to know how he is going to do it, or if I could do it before I bring him the lsd and tranny... Thanks for the heads up.
Old Mar 19, 2003 | 06:23 AM
Wes V's Avatar
There are three ways to get the bearings on;
1. use a press
2. heat up the bearing (or carrier) to the point where it expands, allowing it to slide on
3. beat it with a hammer, hopefully with a soft brass piece in contact with the bearing.
Now think about this, you paid better than a grand for the Quaife and bearings ----- do you really want somebody beating on it with a hammer or heating up stuff to a temperature where it may lose temper?
Wes Vann
Old Mar 26, 2003 | 03:00 PM
b20guy's Avatar
Default Re: Quaife/Carrier bearing install, how-to? (Wes V)
no, but actually i used cheetah's method and in went smoothly!
Old Mar 26, 2003 | 05:48 PM
rex_boy's Avatar
I paid $40 to have the old bearnings removed, spedo gear swapped, final drive swapped and new bearings installed. It seemed fair enough to me.
Old Mar 26, 2003 | 06:07 PM
Nameless RB26's Avatar
Default Re: Quaife/Carrier bearing install, how-to? (rex_boy)
Don't waste money on getting it done.
I placed the bearing in the oven at 300 degrees, and the LSD in the freezer. It drops right onto it.
But the speedo gear might be harder.. I've never messed with that.
vtechjunkie
Transmission & Drivetrain
Sep 14, 2011 11:49 AM
speeddave
Apr 29, 2009 11:35 PM
Boosted Chemist
Nov 6, 2008 07:23 PM
IHTFP
Oct 11, 2007 02:32 PM
ABK
Jan 22, 2007 08:46 AM
