Back to square 1
Old Mar 18, 2003 | 05:45 AM
cr-x si's Avatar
Default Back to square 1
ok i thought i fixed my idle by cleaning off my AICV but when i put it back in i forgot to plug it back into the wiring harness. So that caused it to idle good. But then i went to drive it today and it drove like ****. So i looked it over again and saw that it wasn't pluged in, i pluged it in and now the idle id going up and down again!!!! What dose all this mean. Is there a hose somewhere that is bad or is my AICV bad????
Old Mar 18, 2003 | 01:36 PM
cr-x si's Avatar
Default Re: Back to square 1 (cr-x si)
anyone?
Old Mar 18, 2003 | 02:15 PM
Vinceg99's Avatar
Well first its IACV not AICV. I would say replace it completely and see if it helps otherwise check your fuel filter or your injectors.
Old Mar 18, 2003 | 02:30 PM
wickedEFguy's Avatar
sounds like your IACV is going bad or is hella dirty, I had the same problem on my mazda truck until I replaced it. Also are you throwing any codes and/or tried a different map sensor?
phatbuddha
May 20, 2013 10:46 AM
ProjectEvilEj2
12
Jun 16, 2012 09:05 AM
JDM_SOHC
24
May 9, 2005 08:59 AM
allmotorsi04
May 11, 2004 04:49 PM
civicracer1993
Feb 24, 2003 07:25 PM
