Will a JRSC fit a H22 in an EG+ ?
Hey gang
Just wanted to know if there were any clearance issues with a JRSC and an H22 when installed in a 1993 Civic DX HB?
Anybody with experience with this please let me know.
Thank you
Jon Black
Thank you
Jon Black
This is a car that i took a Pic of at the Carlisle car show. I doubt that you will be able to fit the JRSC in there..... Why not go with Turbo?
So is that an EK. Sorry, but I am pretty new to telling the generations apart. I really dont want turbo, too many things tell me no about it. I want this for the street, and I want stealth because I dont want somebody seeing a big intercooler and then stealing my car. So, the JRSC will most likely suit my needs and my goal of 220 WHP.
Thanks
Jon Black
Thanks
Jon Black
I've actually seen a JRSC H22 powered EG. The car moves out like a bat out of hell. I'll ask my friend to check it out because he works with the guy that has it. The only thing he told me he had problems with the axles breaking because of so much power. I really don't think it will be a problem about clearance if you use the mount kit. I like superchargers more than turbo anyway. Be different get the supercharger. I'll check later tonight.
and the pic above is a prelude not an Ek
I hope this guy above can get pics of that EG setup he knows about. I really want to do this if I can make it work.
Jon Black
I've been trying to find this too. No one ever supercharges anymore, and I think that a charged H22 Hatch would be absolutely rediculous
just what I'd like to have
Scott
Scott
it dont fit at all..unless highly modified some wierd way. Take a look at an H22 swaped hatch and see how close the motor sits to the shock tower. No room at all. It would me mean though
That's an old pict that I took way back when on my old car. I have some better picts, but not uploaded but point being you can see that there's very little room to none for the belt to fit in there w/out touching the shock tower.
Should your friend br breaking axles because of "too much power" - I would suspect this motor/tranny placement is out of alignment, thus causing uneeded stress on some parts, axles just become the weak link.
Well if you were too SC the motor then i hope that you would know enough that you don't run stock axles! Just order DSS stage 3's. That would take care of the issue of the axles.
I agree with Newman.... There appears that there would be almost NO way that you would be able to mount that in the car. But with enough $$ anything is possible.
Run the Turbo. Paint the IC black it would look like a Rad. Unless you STUDY the front of the car your in the clear
