Simple Clutch Slave Cylinder Question
Old Mar 17, 2003 | 08:53 PM
intekragsr's Avatar
Default Simple Clutch Slave Cylinder Question
On my slave cylinder, the lottle expanding boot thing is torn. I was told it was fine but I really dont think so. Is it ok if there is a little tear in it or is it supposed to be air tight?
I was trying to get pressure in my clutch pedal but i couldnt. I tried bleeding and all that stuff but it just wouldnt get pressure. I just need to know if it is because of the slave cylinder boot.
Thank you
Old Mar 17, 2003 | 08:56 PM
white4drint's Avatar
Default Re: Simple Clutch Slave Cylinder Question (intekragsr)
car is dope, what kind of rims, i am lookin for ones that go wit a white teg
Old Mar 17, 2003 | 09:00 PM
intekragsr's Avatar
Default Re: Simple Clutch Slave Cylinder Question (white4drint)
thanks. the rims on my car are the stock gsr rims???? what rims are you talking about....
anyway....bump for the help on this topic
Old Mar 17, 2003 | 09:05 PM
garados's Avatar
I dont think a torn boot would do anything like get rid of pedal pressure. I don't even think that the boot could possibly be air tight. Have you checked your master cylinder?
Old Mar 17, 2003 | 10:10 PM
yisoulja's Avatar
Default Re: Simple Clutch Slave Cylinder Question (garados)
I was told that if there ever is anything wrong with your slave or master cylinder to replace it immediately especially if you have an aftermarket clutch. I guess you dont get enough pressure to the clutch and then in return your clutch will start to slip. just tellin u what someone told me.
Old Mar 17, 2003 | 10:52 PM
MisterHYBRID's Avatar
Default Re: Simple Clutch Slave Cylinder Question (yisoulja)
I would check the master and slave cylinder and see if they're leaking internally.
Old Mar 17, 2003 | 11:30 PM
intekragsr's Avatar
Default Re: Simple Clutch Slave Cylinder Question (MisterHYBRID)
nope they are not leaking. Maybe I am bleeding it wrong? Can someone give me some pointers?
I am basically hooking a tube to the drain hole, and tube submerged ,and pumping like there is no tommroow and it is not doing anything What am i doing wrong or am i skipping a step?
Old Mar 17, 2003 | 11:44 PM
97hb's Avatar
Hook a tube from the drain bolt and submerge the tube in brake fluid. Next have someone depress the clutch to the floor. While they are holding it against the floor you have to turn the drain bolt with a 8mm box wrench and you will hear it squirt out. As soon as it stops squirting, close the bolt back up and tell the person to let off the clutch, sometimes the clutch will be stuck to the floor so you must pull it back to normal height with hands. Keep doing this until a steady stream comes out the tube into the brake fluid. Any bubbles and you must keep repeating the process.
Old Mar 17, 2003 | 11:54 PM
intekragsr's Avatar
Default Re: Simple Clutch Slave Cylinder Question (97hb)
thank you so much.....!!!!!!!!!!!!!!!!!!!
on me thinking i can do it by mylsef. I tied a hockey stick to the pedal and was juss sitting there churning butter.
on average, how long does this whole process take? i heard it takes 2 hours?
[Modified by intekragsr, 8:55 AM 3/18/2003]
Old Mar 18, 2003 | 01:15 AM
akhom2's Avatar
Process takes like 10min.
Just make sure to keep the reservoir full. Don't let it empty out or you will get air in the system and have to start over.
[Modified by akhom2, 10:16 AM 3/18/2003]
kizzkizz10
Dec 9, 2011 10:18 AM
Born2Build
May 22, 2011 06:02 PM
matto2413
Sep 11, 2005 09:01 PM
superfuji57
Sep 28, 2004 01:02 AM
intekragsr
Mar 18, 2003 06:38 AM
