stripped threads on spark plugs??
Old Mar 17, 2003 | 08:37 PM
prjctCIVIC's Avatar
Default stripped threads on spark plugs??
i was changing the spark plugs on my integra and noticed the spark plugs had been misthreaded from the previous owner and was wonderin if i had to pull off the head to rethread it or can i rethread it with the head intact?? if i keep the head on the motor, what about the metal shavings that are goin to fall into the cylinder?? need some advice, thanks in advance
Old Mar 17, 2003 | 09:16 PM
the DR.'s Avatar
Default Re: stripped threads on spark plugs?? (prjctCIVIC)
you're going to have to 'chase' the threads, or retap it depending on how bad its stripped, the shaving shouldnt be too much of a problem, most of it stays on the tap itself.. but if its really bad you might have to use a helicoil..
Old Mar 18, 2003 | 04:04 AM
JimBlake's Avatar
... if i keep the head on the motor, what about the metal shavings that are goin to fall into the cylinder??
Try putting a bunch of grease on the tap. That'll trap lots of the shavings.
Old Mar 18, 2003 | 04:06 AM
speedymon's Avatar
Default Re: stripped threads on spark plugs?? (JimBlake)
Pull the head and do it. Much cheaper than scared cylinder walls.
busta7777
Feb 9, 2011 04:01 PM
Ep1dem1c
Oct 24, 2007 06:34 PM
ITRFetish2000
May 21, 2004 07:18 AM
digitalcongo
Nov 12, 2003 07:49 PM
rastropovitch
Feb 25, 2003 02:22 PM
