help with d15b
A friend of mine just swapped in a jdm d15b into his 90 si. He just got a p28 ecu for the vtec. He wants to know if its a direct swap from the stock ecu. does it plug right in?
The P28 will not plug in to the Si harness. Get a wiring conversion harness and then it will be plug and play. Do a search on the topic, there are a few members on this board who make the harness that you need.
Thanks I tried searching but came up with nothing
Thanks though Redline
[Modified by BADGUYNY, 5:29 AM 3/18/2003]
Thanks though Redline[Modified by BADGUYNY, 5:29 AM 3/18/2003]
with the p28, he will need to convert to obd1
enven with the p28, except if he run 2 o2 sensor, he will get a 41 code,
that's my setup so I know pretty much what came up with these.
see ya
don't hesitate if you got question, Stetcher@hotmail.com
Kranked
see ya
Kranked
hondaracing1
Dec 26, 2004 09:38 AM
essex
Apr 15, 2002 07:37 AM
