Brake Failure
Old Mar 17, 2003 | 07:37 PM
Nacho169's Avatar
Default Brake Failure
So neither of my rear wheels will turn freely with the car in the air and the e-brake off. The passenger side is stuck, the driver side turns with quite a bit of effort. What is the best way to fix this problem? Since both sides are stuck, i doubt the calipers are broken. What's the best way to go about inspecting/fixing/replacing the E-brake cable?
[Modified by Nacho169, 4:37 AM 3/18/2003]
Old Mar 17, 2003 | 08:24 PM
Rtzx9r's Avatar
GDD 1%
Default Re: Brake Failure (Nacho169)
Take off the wheels, and disconnect the e-brake cable from each side. (a spring thing is all) If the problem is still there, and I would bet it will be, you'll have to take off the calipers and lube the slides. This is what lets the caliper "float" around the disk, and it moves when you apply the brakes.
There are 2 sliders on each side, and they need to be taken out, lubed with high-temp grease, and then re-installed. They will slide in and out like a good time w/ your g/f.
This should solve the problem, but you may also need to turn in the pistons (I think you screw them clockwise) so you can put it all back together.
Don't step on the brake pedal when the caiper is off, or you'll have a mess. (don't know how good you are with brakes)
Old Mar 18, 2003 | 10:43 AM
Nacho169's Avatar
Default Re: Brake Failure (Rtzx9r)
anyone else have any tips before I start wrenching?
Old Mar 18, 2003 | 01:05 PM
JimBlake's Avatar
He pretty much covered it. You gotta take a look. Maybe after you take off the handbrake cables, make sure the levers they were attached to can spring back to their 'not-applied' position. Then you just have to see what's still tight.
Old Mar 18, 2003 | 01:20 PM
Nacho169's Avatar
I completely disconnected the parfking brake cable in the pasenger compartment, but it still drug a little bit. I treid to take the calpier off, but it seems the bolts aren't going anywhere, either because they've been heated in place (i guess that's possible) or corroded. Eitehr way, it's going to have to see a shop, my hand tools can't do anything against the caliper bolts
Daywalkin
May 30, 2010 10:39 AM
camelian
Nov 22, 2007 12:53 PM
Turbo Dan
Aug 8, 2006 07:05 AM
SonicGSR
Mar 31, 2003 06:39 PM
MRSI00
Jul 11, 2002 02:49 PM
