gaskets
Old Mar 17, 2003 | 03:50 PM
JasonBlackEJ1's Avatar
Default gaskets
i've just received a new z6 and was told that i should put in new gaskets. the motor has 72k on it and is coming from a salvage yard. what all should i do to it before i install it? and if i should get new gaskets, how much do they cost and what would be the best place to get them? thanks for all the help guys
Old Mar 17, 2003 | 04:33 PM
JDMjdawg's Avatar
Default Re: gaskets (AllShowNoGo)
You should get a new timing belt and oil filter for sure. You should also consider a new water pump too maybe some spark plugs. I don't know, hmm............ Anything else guys?
Old Mar 17, 2003 | 04:41 PM
Bailhatch's Avatar
Default Re: gaskets (JDMjdawg)
What gaskets? I would do the ones that are obviously leaking if you can tell (motor could be washed). Unless you have lots of "tune up" money in your install budget i would just do the basics -fuel filter, plugs, cap, rotor, t-belt. tensinor, water pump, oil change, maybe a thermostat and plug wires at most.
Also doing a rear main seal is tit when the motor is out. I would do poly shift bushings too $11. They help a little and you will have the linkage apart anyway.
I guess it depends on milage too. If you know what it is.
Old Mar 17, 2003 | 04:43 PM
Bailhatch's Avatar
Default Re: gaskets (Bailhatch)
oh ya 72K.
Old Mar 17, 2003 | 10:53 PM
ok. thanks guys. well, i just got a new water pump on my old engine so nothings wrong w/that. were gonna change out the t-belt just to be safe and im gonna get all new gaskets to be safe too. cuz it would really suck to blow something and have something important go wrong.
pho iz good
15
Jun 6, 2017 12:58 PM
civlxbro
Jan 8, 2009 02:42 PM
mrinno
Sep 19, 2007 04:55 PM
dman81
Mar 9, 2005 01:51 PM
rodvang
Dec 16, 2004 08:59 AM
