3 tech questions for a 94 accord, helpp!!!
Old Mar 17, 2003 | 02:40 PM
Mike813's Avatar
Default 3 tech questions for a 94 accord, helpp!!!
1st. Question-
the cooling fan been going on and off ALOT,
it mainly turn on the most 4-5 times people say,
after i shut off the motor, but it goes on for like 10-11 times...
do anyone know whats the problem with this??
2nd. Question-
when i hit first gear, there seem to be like a slight lag,before it gets the go,,
is there anything i can "DIY" to adjust this?
just to quicken my pick up speed a little...
3rd. Question- Tranny prob..on a auto..
when i pull my gears down to drive,
a crank sound happens, anyone know if thats any harm??
my cars on a slight tilt cause of my driveway,
was wondering can it be the tranny fluids rolled to the back?
and my gears are not moistened?
i have no clue at all bout tranny, any comments + oppinions are welcomed.
thanks..
Old Mar 17, 2003 | 03:03 PM
hagrid's Avatar
Default Re: 3 tech questions for a 94 accord, helpp!!! (Mike813)
1st. Question-
2nd. Question-
thanks..
if you have auto, what do you mean hit first gear? please elaborate
Old Mar 17, 2003 | 03:25 PM
Crono139's Avatar
Default Re: 3 tech questions for a 94 accord, helpp!!! (5th Gen)
Drive 1 maybe?
Old Mar 17, 2003 | 04:59 PM
crafty's Avatar
1.) Do a radiator flush, and depending on your mileage change your thermostat
it should help keep your engine cooler.
2.) Not to sure based on your explanation of your problem maybe try adjusting your throttle cable
3.) Again depending on your mileage you may try changing your transmission fluid and if that doesnt work try backing into your driveway
Old Mar 17, 2003 | 06:15 PM
hagrid's Avatar
Default Re: 3 tech questions for a 94 accord, helpp!!! (Crono139)
Drive 1 maybe?
well then it wouldn't necessarly be "hitting" first gear would it?
Old Mar 17, 2003 | 07:07 PM
Jago's Avatar
It dosn't sound like you have any problems
it is supposed to do all those things
Old Mar 18, 2003 | 01:44 AM
Mike813's Avatar
Default Re: 3 tech questions for a 94 accord, helpp!!! (crafty)
Where is this located? sorry im a noob to cars,
everything is a blur ;[ if u have a pic that would help.. ;\
thanks
Old Mar 18, 2003 | 08:04 AM
TouringAccord's Avatar
H-T Order of Merit
thanks
It's located on your intake mani. If you have cruise control, there will be two cables that you will see. The throttle cable is the one closest to the firewall. Hope that helped.
Old Mar 18, 2003 | 08:19 AM
H-T Order of Merit
Default Re: 3 tech questions for a 94 accord, helpp!!! (TouringAccord)
https://honda-tech.com/zerothread?id=244065
At the bottom of this thread, niedejb explains how to adjust the throttle cable. Just in case you wanted to know how to adjust it.
Old Mar 18, 2003 | 09:04 AM
Mike813's Avatar
thanks touring, that helped 100%, thanks to the rest of the guys for helping also..
Old Mar 18, 2003 | 09:06 AM
H-T Order of Merit
no problem.
Old Mar 18, 2003 | 04:19 PM
Mike813's Avatar
ok i adjusted the cables, this other guy said i have to turn some screw at the front near the sensor, with a flat head to adjust the idle?? is this true?? if so, what is that for?? thanks...
Old Mar 18, 2003 | 04:52 PM
Can't Catch Me's Avatar
When you park your car on your driveway, make sure to pull up the e-brake (aka parking brake) so that when you let off the brakes, your car won't slide forward or backwards...this should prevent any harm from putting your car in gear when you're parked on an incline.
Old Mar 19, 2003 | 03:29 AM
H-T Order of Merit
https://honda-tech.com/zerothread?id=346498
Theres another artical by niedejb. In it he explains how to adjust the idle. Hope this is what you were looking for.
fufix
Jul 27, 2013 10:37 PM
marshonda
Feb 21, 2013 06:38 PM
DnB TeK
Oct 1, 2007 09:58 AM
TegBen
Apr 23, 2003 08:52 AM
