urgent...!!! O2 snesor wiring ?
Old Mar 17, 2003 | 02:05 PM
dfoxengr's Avatar
Default urgent...!!! O2 snesor wiring ?
i am a flaming idiot...i looked and do have the 4wire one..lol..the guy that did my swap told me i had 1 wire..sorry
[Modified by hybridvteceg, 1:14 PM 3/18/2003]
Old Mar 17, 2003 | 02:42 PM
splitime's Avatar
Default Re: urgent...!!! O2 snesor wiring ? (hybridvteceg)
If you have a Single wire o2 i think you are out of luck. You need to buy a 4wire o2 to be compatiable with pretty much all the normal ECUs.
Old Mar 17, 2003 | 03:23 PM
Sasebonian's Avatar
try getting and LX or EX wiring harness. those have 4 wires.
Old Mar 17, 2003 | 04:11 PM
DR. ON POINT's Avatar
Banned
Default Re: urgent...!!! O2 snesor wiring ? (Sasebonian)
u cant convert it buddy...Ill check the garage and see if I got one lyin around....... if not just go buy the greddy a/f guage... its 240 and comes with a 02 sesr
Old Mar 17, 2003 | 05:31 PM
dfoxengr's Avatar
Default Re: urgent...!!! O2 snesor wiring ? (splitime)
i run a p28 ECU and DAVID...jeremy at inline said you can... lemme know if you have one...
Old Mar 17, 2003 | 05:32 PM
dfoxengr's Avatar
all i really need is to run the single wire (signal wire) to the white wire on the ecu, which is the O2 signal correct, and it should give a reading to the computer./...
Old Mar 17, 2003 | 05:53 PM
navin's Avatar
if you dont find one..
http://www.oxygensensors.com
OEM replica 02 sensors, the guys at Inline were pretty impressed when I brought mine in, it was only $70!
Banned
oh Jeremy know lot more than me check here http://www.jdmfan.com/technical/perf...obd1/index.inc
by the way i dont have one
Old Mar 17, 2003 | 06:07 PM
dfoxengr's Avatar
Default Re: urgent...!!! O2 snesor wiring ? (DR. ON POINT)
come on dave help me out, lol...
and thanks for the O2 shop link
also heres my deal... 4wire sensors are self-heating...and 1 black and 1 green are grounded, the other black is ignition or switched power, and the white wire is the signal... CORRECT?
since this is true, and i dont have or need a selfheaating one, and am just trying to get my ecu to read the voltage, y do i need the other 3 wires, y cant i just splice the single white signal wire into the ECU white signal read wire? doesnt that make sense...?
[Modified by hybridvteceg, 10:09 PM 3/17/2003]
Old Mar 18, 2003 | 09:14 AM
dfoxengr's Avatar
///Nick
Dec 16, 2009 11:54 AM
ham
May 31, 2006 01:49 PM
SkElLyTuRbO
Oct 6, 2005 03:27 PM
vladd
Dec 5, 2003 08:42 PM
RSZero1
May 13, 2003 08:29 AM
