OT: REALLY need help power windows!
i posted in the tech forum too, but i need some help ASAP!
just got back from a nice trip to mc donalds, the weather was nice, so i rolled down both windows in my 95 rs. when i came home, i was about to roll back up my windows only to relize they don't work. fuses are all good, was kind of wet outside, but would that make a difference? i need this fixed fast, as my neighborhood isn't a good place to be for an open-windowed integra. TIA.
the pusher pins on the back of my passenger window switch were loose not making good contact, thought it was my actual switch or my motor at first. are neither one of the windows working?.....if not check the fuses underneath the hood for a fuse related to the power windows, not just the ones in the car.....not sure if there is a window related fuse underneath the hood but it wouldnt hurt to chck, b/c if both stopped working it sounds suspect
I have an almost similar problem...my passenger window does not work. I've checked both fuses under the dash and under the hood...they are both fine. The driver side window works fine...no problems...but the passenger won't work at all using the driver-side switch or the passenger-side switch
I have yet to check the passenger switch itself...if it is the passenger switch, why would it make it so that the driver-side switch won't work the passenger window?
well BOTH my windows aren't working, i checked all 4 fuses related to my power window, and nothing seems to be blown. it's weird because i just finished doing my 98+ conversion, and left out my fender lining because i was going to work on the fender the next day, i checked the fender wells, and doesnt seem to have any wires in there that can be exposed to water. anybody have any more suggestions? my car is sitting outside with plastic over the windows, it's a sitting duck as it is.
I just got my passenger window to work. Got a voltimeter and checked each wire going into the switch harness to make sure each had juice, which it said they all did. So plugged the harness back into the switch and voila...it worked. Looks like the wires weren't making good contact to the harness connectors and by shoving and probing the connection, it pushed everything back into place. You may want to try doing this.
i have a similar problem my windows, sun-roof and wipers only work when they want to. All my fuses are good but when i go down to check them and put a bit of presure on them it clicks, then i let go and it clicks again. When i put pressure on the fuse box it clicks and my windows and sun-roof and wipers work but as soon as i let go they stop working. This will happen for a couple of days, then everything will start to work like normal. i get this problem at least twice a month.
