Went to The junkyard today to get my mpfi parts. got a few ?'s
Old Mar 17, 2003 | 12:34 PM
wannab20hatch's Avatar
Default Went to The junkyard today to get my mpfi parts. got a few ?'s
I already searched for this but got nothing. I went to the junkyard to get my mpfi parts but they didnt have any crx or civic si's out there. only dx's. My questions are can i use a hf dizzy instead of si and can i use a d16a1 intake manifold and ecu instead of d16a6? Thanks for the help
Old Mar 17, 2003 | 12:38 PM
RenoRacing's Avatar
Default Re: Went to The junkyard today to get my mpfi parts. got a few ?'s (wannab20hatch)
you can use the hf dizzy, and i believe that you can you the manifold, and yes you can use the ecu.
Old Mar 17, 2003 | 01:08 PM
DJ_SaNdOz's Avatar
Default Re: Went to The junkyard today to get my mpfi parts. got a few ?'s (HavokRacing)
would teh a1 manifold flow better than the a6?
Old Mar 17, 2003 | 01:52 PM
zCivic's Avatar
Default Re: Went to The junkyard today to get my mpfi parts. got a few ?'s (dj_sandoz)
pretty sure cann't use a A1 intake manifold, can use the HF dunno why....Find a Z6 or a Y8 intake both will bolt up fine. If you have to use a HF ECU or get one out of a 88-89 teg...Diz the HF is fine
Old Mar 17, 2003 | 02:08 PM
TheJuggalo's Avatar
I don't think you can use the a1 manifold. Looks the same as the a6 but from what I remember the throttle body and manifold are smaller than the a6.
Old Mar 18, 2003 | 09:09 AM
Default Re: Went to The junkyard today to get my mpfi parts. got a few ?'s (TheJuggalo)
What about a 92-95 dx manifold? Thats about all they have.
Old Mar 18, 2003 | 10:16 AM
Redline130's Avatar
That would work as well.
Old Mar 18, 2003 | 10:25 AM
Urban Business
Guest
Posts: n/a
Default Re: Went to The junkyard today to get my mpfi parts. got a few ?'s (Redline130)
what ever dizzy you use, make sure its an obd0 7 wire.
Old Mar 18, 2003 | 10:39 AM
Aron Parsons's Avatar
Default Re: Went to The junkyard today to get my mpfi parts. got a few ?'s (limoZeen)
You can use an HF/Si distributor. They are the same, as both came from OBD-0 MPFI vehicles. As for the intake manifold, get an A6 or Y8 manifold. Others just won't cut it. I'm sure someone has one for sale on here or on the thepartstrader.com for cheap. Also, make sure you get the injector resistor. Many people seem to forget this while acquiring parts.
Old Mar 18, 2003 | 11:23 AM
Vinceg99's Avatar
Default Re: Went to The junkyard today to get my mpfi parts. got a few ?'s (Aron Parsons)
You can also use the Z6 intake.
Old Mar 18, 2003 | 11:29 AM
Rywire's Avatar
Default Re: Went to The junkyard today to get my mpfi parts. got a few ?'s (Vinceg99)
I have a complete manifold for sale from my 91 civic si. pg831@lycos.com if interested. Ryan
Old Mar 18, 2003 | 12:43 PM
MADEINIRAQ's Avatar
Default Re: Went to The junkyard today to get my mpfi parts. got a few ?'s (droppedcrxsi)
joshwhe on this board is selling a bunch of multiport parts.. including pm6(si) ecu.. hit him up with an im.
as stated above.. you need a 7 wire dizzy. hf and si will work
Old Mar 18, 2003 | 02:41 PM
Why wouldnt a 92-95 dx with a crx si fuel rail and obd 0 harness work? Abnd i already have a resistor box. I dont care about makin it fast with an mpfi swap i just want my car moving again.
Old Mar 18, 2003 | 02:46 PM
Urban Business
Guest
Posts: n/a
you would need obd0 injectors w/ the 92-95 dx. id think the manifold itself would fit just fine.
liquidoblivion
13
May 19, 2011 12:07 PM
crxricer66
Feb 13, 2008 07:54 AM
eumoria
Dec 8, 2004 02:05 PM
89dxhunchback
Jun 15, 2003 12:24 PM
