Having problems with my B16 Swap, Help!...
I am having 2 different problems with my B16 swap
1. I am having a problem with the wiring of the motor, 4 out of the 5 clips connect to the car, however the white clip on the drivers side of the car does not fit into the B16 harness, the b16 harness has 13 pins, while the crx one has 8, is this the clip where i wire all my own Vtec wires? if so, shoudln't it only b e 4 wires? ( I have a '91 CRX HF BTW)
2. I can't seem to find the speedo sensor, i looked where the original one was on the original motor, but on the B16, there is a box with wires clipped into it (I have a Y1 Tranny)
I am trying to finish the swap tonight, if someone could explain what i have to do to make it work, i would greatly appreciate it
Thanks
Thanks
From: A place where stupidity runs rampant aka NorCal
-Todd
my car is MPFI, so why would i need to convert it?
what needs to be done to make my harness work with the other? can i just cut both off and connect the wires of the same color?
i assume this is where the wires are for vtec?
how do i replace the VSS with a mechanical one?
do i have to remove the transmission to do this? the motor is in the car already, willl i have to pull the tranny to do this?
what will happen if i don't convert it from an electric one to a mechanical one?
You dont have to pull out the tranny...the VSS sits on top of the tranny, somewhat underneath the TB...I thought you saw the black box with wires sticking out...just unscrew and pull out, unless you're referring to a different box. Anyway, if you dont convert from electronic to mechanical, you wont be able to run your speedo and (no speedo=no vtec). Another option in case you want to keep the electronic VSS is to convert to an electronic or JDM SiR cluster. Either way, you have to deal with the wiring. Let me know, if you need anything else.
so all i have to do is unbolt the box?
i appreciate all your help by the way
the other question is, what do i do about the harness
I was thinkin that i should cut both ends off and connect the wires that are the same color, but what do i do about the extra 5 wires? are those the vtec wires?
Thanks
Thanks
dont cut any wires! check http://www.hasport.com and follow their instructions on quick wiring "how to"...I can walk you through the process but read on first so you'll know what's going on. You need to add 4 wires from your ECU to the connector and from the connector, you need to add wires to the sensors if yours dont fit. (knock sensor, vtec solenoid, vtec oil pressure, 2nd O2)
Yes, i have read that thoroughly
I just got a chance to look at the motor, do you know if it is possible to be able to even run the factory B16 harness?
i understand what needs to be modified on the ECU end, but what do i do in the engine bay area?
I looked at the wire colors on the factory B16 harness and only some of them are similar to the ones on the CRX harness
what can i do to make this as simple as possible? this swap is becoming a big headache for me, i am about to give up on this car, I have been working non-stop for about a week on it, but there have been so many issues with parts not working that i have no will to even look at the car anymore
I truly appreciate your help with my swap
any help would be great
Thanks
Thanks
aight dude heres the problem with the clip that is for the wires for the vtec my friend had that problem with his swap so he had to sauder the wires into the ecu and for the speed sensor you will have to get one from the acura dealer cause it doesnt have one you have to get one for like a 92 93 acura integra goes right in there and its like 90 bucks from the dealer aight buddy good luck
Sorry but I dont know what a B16 harness looks like but to get your motor to run just add the 4 extra wires from your ECU to these sensors...if you're not sure if you already have them...trace these colored wires to your ecu...But I'm almost positive that you dont have them yet so just add these wires and you should be good to go. I'm assuming that you already upgraded or you have mpfi. Make sure that these wires are connected to your ecu as well...A3 Yel Injector #4, A7 Red Injector #2, B10 Orn CKP (connects to distributor), B12 Wht CKP (connects to distributor).........additional wires C8 (white) Secondary O2, A8 (Grn/Yel) VTEC Solenoid, B5 Blu/Blk VTEC Oil Pressure, B19 Red/Blu Knock Sensor
done use the b16a wire harness its way to much work use your stock harness and add 4 wires its alot easyer i used my stock harness cause the b16 had like 20 wires in different places.
that is what your speedometer sending unit on the b16 tranny should look like. u need a mechanical one. call 916-638-3311 thats the number for HAP recycling in cali. ask for a mechanical speedometer sending unit out of a 90-91 acura integra. their 45bucks plus shipping and garenteed to work or u get anotherone for like 6 months. u can also email them but i don;t have the adress.
alright well i replaced my VSS last night, so that is no longer a problem, I also transfered my wiring harness from the old motor to te new one, so now my problem is, where do i connect the 4 additional wires, i have found 3 out of the 4 wires, i think the one i don't have is the knock sensor
there is actually 5 wires,
vtec pressure switch
ground wire off pressure switch
vtec solenoid
2nd o2 sensor
knock sensor
vtec solenoid
2nd o2 sensor
knock sensor
i think i have located the oil pressure, vtec solenoid and the 2nd o2, but where is the knock sensor?
where do i connect the wire for the knock sensor? is there a clip back there?
my friend swapped the harness so i am not sure where everything is
Thanks for your help!!
i'm doin the best i can, this is my first honda swap, everything is just now starting to come along, hopefully once i get the whole axel situation figured out, i should be all set
