b18b bottom end in b18c??????
Old Mar 16, 2003 | 09:57 PM
gumbybum's Avatar
Default b18b bottom end in b18c??????
ok this may be a dumb question but im going to ask it any way, can you use the b18b bottm end in a b18c to acheive the displacement of ls/vtec because its chaging the r/s ratio but it still has the oil feed and the head and all of the essentials for the ls/vtec motor..i would only do this to keep some reliability and maybe save some trouble but i dont know how this well (if at all) this will work???? the only dumb question is one that isnt asked ...and yes i would change the pistons too.
but ya thanx guys for all of the help
Old Mar 16, 2003 | 10:52 PM
gumbybum's Avatar
Default Re: b18b bottom end in b18c?????? (gumbybum)
anyone????
Old Mar 17, 2003 | 12:55 PM
JDubya's Avatar
what do you mean, if your asking if u can use a b18b block w/a b18c head, of course you can. That is an LS/VTEC. You can use any B series VTEC head on a LS block, some machine work just has to be done.
Old Mar 17, 2003 | 06:01 PM
gumbybum's Avatar
Default Re: b18b bottom end in b18c?????? (ALL MOTOR LS)
naa what im asking is can i use the ls crank and rods in a gsr motor to acheive the dsplacement of ls/vtec? because the r/s ratio is diff. so would this work becuse then you could have the power of ls/vtec but also you will remain some what of the stock reliability of a gsr...i havent heard about anyone doing this so i thougt that i would ask you guys...and fr the record i know what ls/vtec is hw and what needsto be done to do it properly but thanx man, just a little confusion (my fault, not too clear) but htanx anyways
Old Mar 17, 2003 | 06:58 PM
gumbybum's Avatar
anyone?????please...
Old Mar 18, 2003 | 09:38 AM
Shft@9GSR's Avatar
No you can't use the LS internals in a GSR block. Reason is deck height. I believe that there is a very minor size difference (but not sure) One is taller than the other I believe??
I'm sure you could if you have the block machined. Also, The cranks have different journal sizes. One has bigger journals.
I have an LS block with GSR internals. Worked fine with some machining from JG.
I know that is going the complete opposite way from what you want, but just saying that I'm sure it's possible with some work. Not just a drop in.
Old Mar 18, 2003 | 09:55 AM
ill phil's Avatar
Default Re: b18b bottom end in b18c?????? (Shft@9GSR)
Actually it can be done, deck height should be the same. Check in the tech forum or search on it, I've seen several people discuss it lately.
ScarCivic
Oct 2, 2014 06:20 AM
iNDyCRX
Dec 15, 2007 12:25 PM
ventuli
Sep 28, 2006 08:09 AM
dingusjt
Feb 1, 2003 01:18 PM
AbaZ
Jul 22, 2002 08:38 PM
