OEM FUEL FILTER REMOVAL...HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Mar 16, 2003 | 09:37 PM
VisualEcstasy's Avatar
Default OEM FUEL FILTER REMOVAL...HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
ok guys i know this should be simple but you would never imagine how difficult it is to get this bastard off. the nut on the end of the fuel line that screws into the bottom of the fuel filter will not, and i repeat WILL NOT, break loose. i cant figure this thing out. i have sprayed wd40 on it and nothing helps. i even started to strip the nut out so i just stopped what i was doing before i did more damage than repairs. can anyone help me out? please for the love of god help me.
Old Mar 16, 2003 | 09:53 PM
nijia555's Avatar
Default Re: OEM FUEL FILTER REMOVAL...HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (BurntRice009)
just make sure that you use an open ended wrench and penetrating oil and you should be ok. the same thing happened to me. dont forget to watch you hands when the bolt loosens
Old Mar 16, 2003 | 09:56 PM
Default Re: OEM FUEL FILTER REMOVAL...HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (nijia555)
yeah used open end 3/4 wrench on fuel filter and 14mm open end on nut on fuel line. i used wd-40 on it but is there something better i should use? i just hope i dont strip it out anymore, otherwise i will probably have to replace that whole section of the fuel line.
Old Mar 16, 2003 | 09:57 PM
fowler!'s Avatar
You gotta man handle it. I had the same problem. But keep trying, it'll eventually come off.
Old Mar 16, 2003 | 10:01 PM
Default Re: OEM FUEL FILTER REMOVAL...HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (fowler)
stock **** is a pain in the ***, i cant wait till i have to do this again with an aftermarket fuel filter.
Old Mar 16, 2003 | 10:06 PM
Racerage1's Avatar
you should try to get yourself a long hollow pipe and place one end on the wrench for some leverage...does wonders for me...
Old Mar 16, 2003 | 10:10 PM
CunninLynguist's Avatar
Default Re: OEM FUEL FILTER REMOVAL...HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (Racerage1)
leverage
If you dont have a pipe or a breaker bar. Then try putting a larger socket on the end or the ratchet the more leverage the better
good luck
Old Mar 17, 2003 | 12:52 AM
all stock's Avatar
Default Re: OEM FUEL FILTER REMOVAL...HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (Rufus)
took me 2 hours to take off my fuel filter. however, within those 2 hours, i had to get a 19mm cuz i didn't have one before...[had a 18mm wrench...just not 19]. just give it some UMPH.
Old Mar 17, 2003 | 01:47 AM
senpai's Avatar
I'm assuming it's a 96-00 Civic since you said the line on the bottom.
Looking from the TOP OF THE CAR, you would have to wrench it clockwise, yes, CLOCKWISE. From under the car ( ), then it'd be counterclockwise. Everyone has problems with this darn filter,
[Modified by maztur, 4:48 AM 3/17/2003]
Old Mar 17, 2003 | 06:51 AM
EG6owner-T's Avatar
Default Re: OEM FUEL FILTER REMOVAL...HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (maztur)
i changed mine in about 20 mins for the first time
Old Mar 17, 2003 | 09:50 AM
all stock's Avatar
Default Re: OEM FUEL FILTER REMOVAL...HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (EG6owner)
it took me 20 minutes once i had a 19mm. everyone said some long nose pliers would do the trick...nah uh....
Old Mar 17, 2003 | 09:57 AM
sil's Avatar
sil
yea.. and don't forget to tighten things before starting the car..
Old Mar 17, 2003 | 10:33 AM
MonkeyMagic's Avatar
stupid question but... when you remove the fuel filter on an eg should you do anything special? or just take all the bolts off like you would to change a light bulb. i've heard you should remove the fuel pump fuse and run the engine or sumthin, but i couldn't find a fuel pump fuse.... any help would b gr8
Nova_Dust
10
Aug 10, 2006 08:16 PM
moonpieboy
Oct 9, 2005 09:57 AM
Ti3d in
Jul 27, 2004 07:57 PM
get wet racing
Jan 6, 2003 06:16 AM
AK94GSR
Aug 7, 2002 08:02 PM
