about to swap a motor
Old Mar 16, 2003 | 08:54 PM
zrdeg's Avatar
Default about to swap a motor
im about to drop a 98 jdm motor.... is it worth it to get a new water pump and oil pump while the motor is still out still or am i over it cuz the motor is still pritty new???
Old Mar 16, 2003 | 08:57 PM
GTlvr82's Avatar
Default Re: about to swap a motor (zrdeg)
First of all...always be specific and secondly...it is always worth it to put in a new water pump and check the oil pump for leakage...if you are eventually going to build the motor you might as well put in a Prodrive Oil pump gear. Just get one that will last a LONG time under heavy-duty driving...That is my .02.
Old Mar 16, 2003 | 09:09 PM
pennies_hatchie's Avatar
Default Re: about to swap a motor (GTlvr82)
definately do it
while your at it, put in a different head gasket as well
Old Mar 16, 2003 | 10:19 PM
aw1234dude's Avatar
Default Re: about to swap a motor (pennies_hatchie)
While you have it out and if you have some extra cash you could put in a new clutch if you need more grabbing powa, but seeing as it is a 98 motor the stock clutch should have plenty of life left. It'll just be much easier to put the clutch in while the entire motors out.
Old Mar 16, 2003 | 10:22 PM
Civichatch972's Avatar
Default Re: about to swap a motor (aw1234dude)
A lightened flywheel would go great with that too.
94whitecivic
Aug 5, 2013 07:10 PM
92integraVTECgsr
Jan 28, 2007 08:25 PM
dunkd
Jun 24, 2004 03:39 AM
johnzm
Aug 11, 2002 09:25 PM
