For those of you who have installed a short shifter...
Old Mar 16, 2003 | 07:54 PM
whizdumb's Avatar
Default For those of you who have installed a short shifter...
I installed my short shifter today, and now it is really hard to get it to go in gear. I have to pull or push really hard... any ideas why? I installed a new ES stabilizer bushing and I'm thinking it might have been the two bolts that hold that in place, maybe they aren't tight enough.
The bushing I replaced is #18 on this picture:
Anyone know why it would be so hard to get in gear?
Thanks!
Old Mar 16, 2003 | 08:03 PM
Scarface928's Avatar
From: Northern Virginia home of missing hondas, USA
Default Re: For those of you who have installed a short shifter... (shiznattik)
Was it hard before you put in the shortshifter?My guess is bolt number 26 is too tight.
Old Mar 16, 2003 | 08:18 PM
jdmWONG's Avatar
Default Re: For those of you who have installed a short shifter... (Scarface928)
your shifter is most likely touching you exaust. making it hard to shift. short shifters place your shiftlinkage really close to your exaust. i took a short shifter out of my car because it was rubbing on my exaust.
Old Mar 16, 2003 | 08:24 PM
PhatHardy's Avatar
Default Re: For those of you who have installed a short shifter... (Blow'N'CRX)
nah, you would know if it was on your exhaust, the problem is you probably tightened bolt 26 too tight, and your shifter probably doesn't have a bearing in it, so it will spin, so loosen the bolt nad put some grease in there, and you should have no problem. It worked for me.
Old Mar 16, 2003 | 08:26 PM
matt j's Avatar
Default Re: For those of you who have installed a short shifter... (PhatHardy)
this is what i did, mine did the same thing yours was doing until i did this and now it works perfectly!
Old Mar 16, 2003 | 09:01 PM
illi Adik's Avatar
It very well could be on your exhaust though, drop your exhaust down some and check after that, I had the same problem.
Old Mar 17, 2003 | 04:06 AM
zcivicz's Avatar
Default Re: For those of you who have installed a short shifter... (Jackson4Door)
yeah make sure you lubed everything up with lithium grease (supplied w/ short shifter - at least my B&M did) and put new rubber o-rings on the bushing. get it right and you'll never wanna go back to the stock shifter.
pS : my stock exhaust system doesn't even come close to the bottom of the short shifter. B&M all the way
Old Mar 17, 2003 | 06:45 AM
Count Blah's Avatar
From: A place where stupidity runs rampant aka NorCal
Sounds like you overtightened #26. Back it off a bit and use some locktite on it.
-Todd
Old Mar 17, 2003 | 07:02 AM
Si_Power's Avatar
i had the same problem when i installed my short shifter. you just have to give it about a week for it to set the bushings and, it will loosen up back to the way it was, everyone i know that has put one in has had the same thing but it will go away after about a week.
Old Mar 17, 2003 | 08:07 AM
whizdumb's Avatar
Default Re: For those of you who have installed a short shifter... (Si_Power)
Thanks everyone, I guess I will loosen up bolt #26 a bit. I tried this while I was under the car and it seemed like the nut would loosen and fall off. Should I just use some locktite?
It's not hitting the exhaust, it's quite a bit away from that...
Old Mar 18, 2003 | 03:55 PM
GreenMachineRex's Avatar
i don't remember but only my 2nd gear is hard to get into ? and i've had a b&m for 5 months now...could it be my snycro or should i also lossen #26
99fbpem1
Aug 31, 2007 08:43 PM
CrX-To-Tha-Max
Mar 17, 2004 11:10 AM
Curtis2kul
12
Feb 13, 2004 10:59 AM
turbo4racing
Apr 22, 2003 05:31 PM
