GS-R cluster into 6th gen civic coupe
I have seen this on a few sites before, and some sights say that it doesnt fit right, while others dont mention this at all.
Has anyone here done this swap, and can you tell me how it looks and what to expect when I do it?
Thanks!!
Thanks!!
WOW!!
Thanks for the fast reply man.
I noticed on JDM fan it says to use plumbing strap....WTF is plumbing strap?
Also, where did u get ur cluster, I am going to try upullrparts just south of the twin cities.
hahahaha your even in the twin cities as well
the plumbing strap i used is from home depot. Its a shiny copper piece with room for a pipe on the top, and alternating sized holes going down. all you need is to cut it a little..nothing serious. (pics will help you ALOT!)
i got the cluster from the HT classifides
edit: dehhh.....i lok momy i kan spel!
[Modified by FifthGearOnline, 10:06 PM 3/16/2003]
ok the strap you want is 3/4" x 12" brass
if you do not do the strap part, it will hold just fine. but if you want a little extra security just go ahead and buy it.
Here are some pics of the gap that you will have around the cluster
heyitsaej8
Jan 7, 2010 10:02 PM
hnp5
May 4, 2005 03:11 PM
