just washed my engine and one hid doesnt work...
Old Mar 16, 2003 | 06:34 PM
Buckshot's Avatar
Default just washed my engine and one hid doesnt work...
i dont know what forum to put this in but a lot of you guys have hids.
anyways i washed my engine this afternoon and when i went to turn on the lights tonight only one of them worked.
i checked all the fuses and they seem to be all fine. then i checked the connectors from the ballasts and the bulbs and there was water in them. so i got it out as best i could and the one still doesnt work.
i hoping the water just needs to totally dry in order to work. but does anyone else have any ideas what to look for?
btw i have the phillips 4300 k kit
Old Mar 16, 2003 | 07:03 PM
type r 01-1063's Avatar
Default Re: just washed my engine and one hid doesnt work... (Buckshot)
Check your fuses. I dont know what else to tell you other than that. Next time remove your HID system.
Old Mar 16, 2003 | 07:07 PM
Buckshot's Avatar
Default Re: just washed my engine and one hid doesnt work... (type r 01-1063)
could it be a different fuse besides the headlight ones?
Old Mar 16, 2003 | 07:08 PM
Dave-ROR's Avatar
screwed up a balast? not sure. try switching the ballasts to the opposite side after it all dries, if the bad side travels with the ballast I'd say the ballast shorted out. if the side that is out doesn't change, check the bulb.
Old Mar 16, 2003 | 07:55 PM
Buckshot's Avatar
Default Re: just washed my engine and one hid doesnt work... (FyrStarter)
i tried to switch the ballasts but i think the bulb is directly connected to each ballast. i tried to "unplug" the wire that the bulb is connected to but it seems to be permenantly attached. i dont wanna go yanking **** if it doesnt disconnect.
does anyone know if you can switch the ballasts?
sorry if this doesnt make any sence, i havent slept in like 38hrs
Old Mar 16, 2003 | 08:09 PM
CPR's Avatar
CPR
Yes, you can switch the ballasts.
Old Mar 16, 2003 | 09:02 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
One of mine didn't turn on the other night. When I got home I shook the connection between the stock headlight plug and the plug-to-ballast pigtail and it came on. *phew* I was afraid the ballast was fried.
Old Mar 16, 2003 | 09:08 PM
Buckshot's Avatar
Default Re: just washed my engine and one hid doesnt work... (CPR)
how u unplug them?
Old Mar 16, 2003 | 09:24 PM
skafia's Avatar
25 Year Member
Ballasts should be insulated and self-contained to withstand weather. I don't see why you wouldn't be able to steam clean your Acura TL Type-S engine bay.
Check your fuses, check your wiring, and maybe, just maybe, check your bulbs. But I think the ballasts should be fine.
Old Mar 16, 2003 | 09:36 PM
skafia's Avatar
25 Year Member
Default Re: just washed my engine and one hid doesnt work... (kittenman)
damn, that sucks, i'll sell you a set for $2000. call me at jdmacuraparts!!! 909-429-5000
WTF? I hope he's kidding.
(JDM Acura parts, lol).
B2FiNiTY's Avatar
Default Re: just washed my engine and one hid doesnt work... (skafia)
909...not suprised
Old Mar 16, 2003 | 09:42 PM
migs's Avatar
God I hope this isnt Eric.
Old Mar 16, 2003 | 09:43 PM
skafia's Avatar
25 Year Member
Default Re: just washed my engine and one hid doesnt work... (Migs)
909-429-5000
"Thank you for calling the California Speedway..."
zer0zer0 TypeR's Avatar
This guy's still stuck in 5 years ago...
Old Mar 16, 2003 | 11:29 PM
MK Ultra's Avatar
1. I never ever wash my engine out of fear of ******* up something important.
2. Stock headlamps own.
Old Mar 17, 2003 | 05:17 AM
Philly_NBP_R's Avatar
Default Re: just washed my engine and one hid doesnt work... (MK Ultra)
The stock headlamps are pretty good, for non-hid's.
I just washed my engine bay yesterday. The trick is to use plenty of simple green, and not too much high pressure water. A garden hose works fine, but spray a FINE MISTING SPRAY over the engine bay, don't direct full pressure at anything. Cover up any exposed, or aftermarket electronics w/ a plastic bag ahead of time. When your'e done cleaning, start the car and let it idle for a while (to dry all components).
For your HID issue, I would get this stuff called electical contact cleaner. You spray it on, and it dry's almost instantly, leaving no residue. This will clean your contacts, and remove any water that may be screwing up your connection. I would clean all wiring connections associated w/ the HID's. If that doesn't work, check the ballasts, as they may be wet. Take em out and let them dry compelely.
You should be able to find electical contact cleaner @ pep boys, or Autozone...
Nick (who's engine bay is blingin today)
[Modified by Philly_NBP_R, 9:19 AM 3/17/2003]
Old Mar 17, 2003 | 10:59 AM
Buckshot's Avatar
Default Re: just washed my engine and one hid doesnt work... (Philly_NBP_R)
well i just checked them today and they work!
i guess it was just moisture related.
thanks for the help
EJ1 RaceBound
Honda Civic (2006 - 2015)
11
Sep 29, 2011 08:13 PM
seabassrsx19
Sep 26, 2008 07:00 PM
kjg8erz8
Aug 1, 2006 11:50 AM
b18bEG
30
Dec 13, 2004 05:26 PM
