where are the drain tubes?
Old Mar 16, 2003 | 03:06 PM
GroundZer0 336's Avatar
Default where are the drain tubes?
my sunroof is leakin at the roof, someone said its the drain tubes clogged, i dont know where they are, help its spose to rain all week!
Old Mar 16, 2003 | 03:53 PM
keithv's Avatar
Default Re: where are the drain tubes? (orgasmobile)
there is 1 in each a pillar and the rears are behind the window trim, but in the back corner.
CRX Si's Avatar
they would run under your A and C pillars...
Old Mar 16, 2003 | 04:10 PM
OK oops, caps, i got another leak problem , this sucks, the hatch struts are dripping, and the back windows are dripping from the tops, can i just get new rubber window moulding for the outside or what?
Old Mar 16, 2003 | 04:11 PM
shortyz's Avatar
yeah my **** gets filled and doesnt drain unless i rock my car
are they hoses that drain it or.. just metal? where do they come out so i can blow them out
Old Mar 16, 2003 | 04:15 PM
ok my rex is now a pool! im thinkin about just drillin a hole in the floor cuz ive got about 2 inches puddled in it, any help its like a monsoon over here.
Old Mar 16, 2003 | 04:21 PM
CRX Si's Avatar
there is a knock out on the floor where the spare goes (looks like a freeze plug) just punch it out and save yourself from drilling
Old Mar 16, 2003 | 04:42 PM
keithv's Avatar
Default Re: where are the drain tubes? (shortyz)
yes there are rubber hoses that drain the water from the sunroof.
Old Mar 16, 2003 | 09:56 PM
crex23's Avatar
Default Re: where are the drain tubes? (breaka_1_9)
I can't help ya with the drain tubes because I don't have a sunroof. But I did have the same problem as you with water dripping off the rear hatch struts. I ran a thin strip of silicon around the rear washer squirter and that fixed my problem.
BTW, if you can't find the source of the leak, at least put a plastic tarp over your car so it doesn't get water inside
Ethan_Accord
Feb 5, 2016 04:17 PM
mnmsddy
Dec 18, 2009 01:41 PM
ep3man
Sep 14, 2008 12:07 PM
VietFoo
Jan 25, 2005 11:06 AM
