when i press the gas all the way down the car bogs and goes slow? why
it never used to do this.. it like limits my speed when i press the gas all the way down.. why? and its not the ECU or engine cause it used to do it and it still does it after my SI swap. its a 93 CX with d16z6????
but its not a cx its SI .. it hesitates a lil when i pull out sometimes.. as if the gas is on a delay??
Same thing here... d16z6. I mash down the gas, there is a delay. 500ms/900ms, then it kicks in.
[Modified by SEVENSIX, 3:42 AM 3/17/2003]
Dirty Fuel filter? My CRX used to do that, my uncle changed the fuel filter, cleaned the injectors and it didnt do it anymore.
thats wierd, My car goes on my demand....when I want my car to go, just put it in gear, mash the gas..and it goes...i also have d16a6
[Modified by WongFeihung, 8:00 PM 3/16/2003]
I have the same problem too with my B16, but i notice that when you want lanched at the line, just easily press it in and then slam on it. for some reason this helps alot in my car. but, changing the fuel filter will help.
i changed fuel filter on mine.. same thing.. i finally realized i drive a cx.......
****..no my tranny whines...
loweg
23
Mar 27, 2005 08:01 PM
mycvc8u2
17
Jul 18, 2003 09:35 AM
