b18c1 in 97 ls ?????
Old Mar 16, 2003 | 10:17 AM
dose's Avatar
Default b18c1 in 97 ls ?????
i justdid the swap,i have a chipped p28 and an obd2 to 1 harness coming and my question is what wires do i need to hook up.i was told
vtec selonoid-yellow/green
vtec oil press-blue
vtec ground-black
evap purge power-yellw/black
evap purgeselonoid-red
if they are all the wires i need where do i find them?at the end of the harnesswhere it plugs together near the battery?
Old Mar 17, 2003 | 04:34 PM
dose's Avatar
Default Re: b18c1 in 97 ls ????? (dose)
comeon guys i need some help
Old Mar 17, 2003 | 05:18 PM
Malice's Avatar
New User
only other one i can think of is the secondary openers. (pink w/ blue pinstripe on herness next to driver side shock)
Old Mar 18, 2003 | 03:17 PM
Bseries's Avatar
if you are using a P28 and a jumper then just add the vtec and vtop the pin locations are vtec A4 and vtop is D6. what year is your B18c1.
Old Mar 18, 2003 | 04:11 PM
dose's Avatar
Default Re: b18c1 in 97 ls ????? (Bseries)
a4 and d6 at the ecu?right ,where do i find them in thw wiring
Old Mar 18, 2003 | 05:14 PM
97hb's Avatar
If your using obd1 ecu dont worry about the evap wires.
djtsmith007
Apr 24, 2007 04:43 PM
dose
Apr 6, 2003 08:25 AM
Jefe06
Oct 3, 2001 07:47 PM
