steering wheel not lined up!
Old Mar 16, 2003 | 05:11 AM
1hotintegra's Avatar
Default steering wheel not lined up!
u just put in new coilovers and a skunk2 camber kit, i dont know if it happend directly after i did that but i just noticed that the steering wheel is off a little bit.. it isnt straight it, its off to the left a little bit
?? anyone??
Old Mar 16, 2003 | 09:00 AM
2lowintegra's Avatar
Default Re: steering wheel not lined up! (1hotintegra)
you need an alignment my friend, that will set you straight... (no pun intended)
Old Mar 16, 2003 | 09:14 AM
.RJ's Avatar
.RJ
lowering the car affects your alignment. Get a tape measure, some string, and re-set your toe.
Old Mar 16, 2003 | 09:28 AM
ITR 01-0422's Avatar
when i lowered my car i got it aligned right away. that'll probably fix your problem.
Old Mar 16, 2003 | 04:46 PM
Default Re: steering wheel not lined up! (ITR 01-0422)
i know the alignment is off but would that make the steering wheel off??
Old Mar 16, 2003 | 05:42 PM
97hb's Avatar
Default Re: steering wheel not lined up! (.RJ)
Yeah, but if you more than 1/2 inch off either way, your lookin for trouble.
Old Mar 17, 2003 | 05:51 AM
JimBlake's Avatar
Yes it could! If the toe was off, & the mechanic got lazy & only adjusted the tie rod on one side, then your steering wheel won't be centered.
If you toe is good, then you center the wheel by shortening one tie rod & lengthening the other by exactly the same amount. But first, check to see that the steering wheel turns exactly the same amount both ways. If it doesn't, then first thing to do is make it so by removing the steering wheel from its shaft.
Old Mar 17, 2003 | 05:54 AM
migs's Avatar
Default Re: steering wheel not lined up! (2lowintegra)
Old Mar 17, 2003 | 08:19 AM
.RJ's Avatar
.RJ
Do you know how a steering rack and suspension works? Seriously.....
http://www.howstuffworks.com
Old Mar 17, 2003 | 11:27 AM
integobsession's Avatar
AHAHahhahaHAHAHaAhAHAHha... but seriously... let's make this simple... an alignment means that the mechanic aligns the wheels. Really really simply put, the wheels aren't facing the right direction... they're pointing lets say left... THEN your steering wheel will be turned left... WHY? because your wheel is turned left. Get an alignment.
easyFOsheezy
Aug 25, 2010 12:26 PM
tonykdee
Honda Civic (2001 - 2005)
May 27, 2009 07:49 PM
Krisgh15
Suspension & Brakes
Apr 21, 2006 02:40 PM
.water
Suspension & Brakes
Feb 9, 2006 10:39 AM
kento
Jul 5, 2001 04:56 PM
