'00 GSR wiring harness same as '00 Civic Si?
no.... the gsr is more like the EG style harness while the Si is all one piece that goes from motor to ecu....
what car are you putting the motor into? and also what ecu are you running?
if you are throwing the 00 gsr motor into a 00 si it will work but you will have to wire in the IAB....
its going into a '00 civic si
You'll have to use your Si wiring harness since it is going into a Si. Like what jdmDXrex and Hybrid95CivicEX said, you'll have to add wire from your ECU to the IAB. That should be pretty much it, the only other thing you might need to do is lengthen some wires, but i don't think you do. Just match up the Si harness to the GSR motor and you'll know. Goodluck
[Modified by PwrByHonda, 12:11 PM 3/16/2003]
just curious, why a gsr into an si? did you blow the stock motor?
you got some reading to do
https://honda-tech.com/zerothread?id=441392
jdmkevin
Jun 18, 2003 06:13 PM
