Tuning is fun
Old Mar 15, 2003 | 03:44 PM
Asahi's Avatar
Default Tuning is fun
Went to the dyno today. I continue to learn about my power FC and the datalogit hardware/FC Edit Software. I will post a pic below. Basically all I did was show up and tun. first run is untuned right after I arrived the last/best run was after about 45-50 minutes of tuning. no new parts just a little tinkering with the fuel settings.
This dyno is low compared to most so I am pleased with the overall result. (Ausmith has even comapred this dyno to Kings and agreed it is low)
my car setup is here http://www.b18c5.net.
Old Mar 15, 2003 | 03:48 PM
Black R's Avatar
25 Year Member
Default Re: Tuning is fun (Asahi)
.....it looks like you didn't do any cam gear tuning. Is this correct?
Old Mar 15, 2003 | 03:51 PM
Asahi's Avatar
Default Re: Tuning is fun (Black R)
Nope, no time. Had one hour and had so many things I wanted to try with the datalogit I focused on that. Used some injecor correction factors and smoothed my A/F curves.
I have stock cams and have come to decide that cam gears are borderline a waste of time for what their return is.
Trey
Old Mar 15, 2003 | 04:02 PM
BimmerSteven's Avatar
Old Mar 15, 2003 | 04:07 PM
Batoutahell's Avatar
I'm glad somebody enjoys dyno tuning. I've had nothing but grief with my dyno shop recently.
Old Mar 15, 2003 | 04:08 PM
Asahi's Avatar
Default Re: Tuning is fun (Batoutahell)
Do tell. Problems with the car of the shop?
Old Mar 15, 2003 | 04:26 PM
Maximus's Avatar
A nice improvement thanks to the Power FC and asahi's tuning.
Old Mar 15, 2003 | 04:37 PM
Type-R Yo!'s Avatar
New User
Nice Trey hope you had fun learning about your power FC and the datalogit hardware/FC Edit Software.
Mickey how hope he will be getting his and learn it too next year.
Old Mar 15, 2003 | 05:50 PM
BudMan's Avatar
Default Re: Tuning is fun (Type-R Yo!)
Trey - do go back for some cam gear tuning...you'll find it was definately worth it for me. I pulled ~4hp higher for the entire curve by the time I was finished.
Old Mar 15, 2003 | 06:10 PM
CPR's Avatar
CPR
Nice gains. Do you have the before and after A/F graphs?
Old Mar 15, 2003 | 06:13 PM
RTW DC2R's Avatar
Default Re: Tuning is fun (CPR)
is that 39 dyno runs?
Old Mar 15, 2003 | 06:37 PM
pyromaster's Avatar
looking good trey
Old Mar 15, 2003 | 06:46 PM
coquinn's Avatar
Default (none)
Looks good ...minus the area from 5000 - 5600.
Nice work.
Old Mar 15, 2003 | 07:04 PM
Asahi's Avatar
Unfortunately the runviewer doesn't see the A/F data. I am around 13.6-13.7:1
Asahi's Avatar
Default Re: Tuning is fun (RTW DC2)
yes. only did 17 today. the other 23 were from the last session.
Old Mar 15, 2003 | 07:05 PM
Asahi's Avatar
Default Re: (none) (coquinn)
Nice work.
I figured why stress over 100 rpms of power plus I can make it smooth like everyone wants but it loses a good bit of power to do it. THere is more area under the curve with the bump, smooth or not.
Old Mar 15, 2003 | 07:37 PM
RTW DC2R's Avatar
oh ok i was gonna say...i felt bad just doing 20 straight runs on my car...and it was the first time running it after the buildup. I still need more dyno and street time though, its not close to done.
Old Mar 15, 2003 | 07:41 PM
YelLowITR's Avatar
i want to learn about tunning too, too bad never have chance
nice power tho, but the carve not so smooth bump for tunning
Old Mar 15, 2003 | 08:26 PM
Angry Joe's Avatar
Leaning to tune is pretty cool, I'm still a little low on the learning curve though
Old Mar 15, 2003 | 11:52 PM
Variance's Avatar
Default Re: Tuning is fun (Angry Joe)
Good gains on the midrange!
Old Mar 16, 2003 | 04:30 PM
Smitdog's Avatar
Default Re: Tuning is fun (Variance)
Good #'s!
Old Mar 26, 2003 | 10:52 AM
W.O.T.'s Avatar
Default Re: Tuning is fun (Smitdog)
With your mods did you have to add or subtract fuel? I've got a ITR with AEM CAI, JDM ITR header, T1r race cat & exhaust. I've heard that the stock ITR ECU runs rich correct? So I'll be ok (not running lean) but may be leaving power on the table?
Aaron.
Old Mar 26, 2003 | 10:55 AM
Asahi's Avatar
Default Re: Tuning is fun (W.O.T.)
Aaron.
I removed fuel but I also have Prelude (290cc) injectors. That said i am hardly using them with what i have. You will be fine but definitely are leaving power on the table
Old Mar 26, 2003 | 10:57 AM
W.O.T.'s Avatar
In your opinion is a fpr even necessary (to add fuel) or would vafc be sufficent as I would only be needing to reduce fuel (to be confirmed and tuned on a dyno of course).
Old Mar 26, 2003 | 11:00 AM
Asahi's Avatar
My opinion might not be as worth as much as others but i personally don't think you wil need an FPR. If you find you are needing mor fuel I think adding an FPR and then trimming out is better than adding fuel with a VAFC but others will have better input.
I think a VAFC will give you good gains but you might look into an S100 Hondata system as well.
Trey
