How hard to install SS brake lines?
Old Mar 15, 2003 | 03:25 PM
conesmasher's Avatar
Default How hard to install SS brake lines?
Just looking for some pointers or anything to help me before I start this project.
Old Mar 15, 2003 | 03:31 PM
.RJ's Avatar
.RJ
Default Re: How hard to install SS brake lines? (snoballgsr)
You'll need 2 liters of brake fluid, A set of flare ended-wrenches, PB blaster, Vice Grips.
Old Mar 15, 2003 | 03:36 PM
Default Re: How hard to install SS brake lines? (.RJ)
So what kind of fluid do you reccomend. I have some ATE super blue at the shop and that is what we use in our race cars. Also how hard do you think it is? Do these things ever freeze up at all such as the lower rear shock bolts.
Old Mar 15, 2003 | 04:49 PM
.RJ's Avatar
.RJ
ATE is good fluid.
Yes they freeze up and rust shut, and are often a b!tch to remove.
Old Mar 15, 2003 | 06:30 PM
cjohnson_2's Avatar
I just did mine a few months ago and I live in Wisconsin where Salt owns everything. . Mine came off pretty easy.. just use the right wrenches. flare end wrenches worked the best.
Old Mar 15, 2003 | 06:49 PM
.RJ's Avatar
.RJ
Default Re: How hard to install SS brake lines? (cjohnson_2)
flare end wrenches are the *only* thing that will not round off the bolts.
Old Mar 16, 2003 | 12:08 AM
qtiger's Avatar
Use flare wrenches not standard.
The $10 you spend on tools will be worth their weight in unstripped flare nuts.
Old Mar 16, 2003 | 07:52 AM
Default Re: How hard to install SS brake lines? (qtiger)
I am pretty sure that we have flare wrenches at our shop, or at least I hope we do, we build race cars for a fricken living. But I am not the most technically savvy person since I work in sales.
InvaderTrax
Suspension & Brakes
Jan 11, 2007 07:09 AM
InvaderTrax
Jan 10, 2007 06:50 PM
youngvedder
Mar 17, 2004 10:31 AM
Flux
May 22, 2003 12:50 PM
Que_Lude
May 13, 2003 07:36 AM
