Engine is in but isn't starting. need help!!!!!!
Ok i finished putting in my zc yesterday, it is all wired up good. It will turn over strong but won't start. It has good spark and strong compression. For some reson the injectors arn't fireing. I have at 89 integra ecu (pg7) and my si ecu (pm6) when the teg ecu is in the light goes crazy i can't even read it. it never pauses it just stays on. When i put my si ecu on, the is no light at all. Why arn't my injectors fireing? I have real strong fuel pressure.
When we sprayed a little engine starter in the throtle body it fired right up. But then died. Do you guys have any suggestions.
I want to get it running today.
89hatchback
Feb 13, 2004 07:05 PM
