need help on how to wires vtec on sohc swap
Old Mar 15, 2003 | 12:29 AM
JDM DC2's Avatar
Default need help on how to wires vtec on sohc swap
i have a 92 lx auto, sohc 1.5 non-vtec.....and i want to put a sohc vtec motor in.....does it fit? and what do i need to do to make the vtec work? what kind of ecu do i need? and what kind of wires do i need to run?
Old Mar 15, 2003 | 06:54 AM
clm's Avatar
clm
Default Re: need help on how to wires vtec on sohc swap (JDM DC2)
From what I've read (which you can do by searching), is basically just bolt it in and plug it in (if I remember correctly - which is unlikely on this subject) - if it's an OBDI engine. The '92s are prewired for VTEC.
Old Mar 15, 2003 | 10:13 AM
JDM DC2's Avatar
Default Re: need help on how to wires vtec on sohc swap (clm)
so your sayin that the 1.5 sohc non-vtec 92 lx is prewired for vtec, so that means all i need is a auto ecu and everything is plug and play?
Old Mar 15, 2003 | 11:08 AM
clm's Avatar
clm
I believe that's the jist of it, but do your own research because I'm unsure of all the ins and outs of swapping engines.
Old Mar 15, 2003 | 11:23 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
nope, only the 92 hatchbacks are prewired for VTEC. You will need a P28 ECU, and add 2 wires from the ECU plugs to the plugs on the passenger side shock tower. These are for the VTEC solenoid (pin D6) and VTEC pressure switch (pin A4). Assuming you get a 92-95 D16Z6 OBD1 SOHC VTEC engine with the engine harness attached, then it will be simple plug n play after you add those 2 wires. See this diagram:
*edit* well this diagram says that all 92 Civics are prewired for VTEC, but I have another diagram that says only the 92 hatchbacks are prewired. I guess just check your ECU plugs and if you have those 2 wires in the A4 and D6 locations, then you're good to go.
[Modified by PatrickGSR94, 2:28 PM 3/15/2003]
Old Mar 15, 2003 | 01:38 PM
JDM DC2's Avatar
Default Re: need help on how to wires vtec on sohc swap (PatrickGSR94)
i have a 92 lx....if i dont get the ex/se harness, how do i find the wires that i need to add from the motor?
Old Mar 15, 2003 | 04:08 PM
JDM DC2's Avatar
bump?
Old Mar 16, 2003 | 10:32 AM
JDM DC2's Avatar
help?
Old Mar 16, 2003 | 10:47 AM
clm's Avatar
clm
You should get the VTEC enabled harness with the motor. Have you tried searching yet? Try the D series board, too.
Old Mar 16, 2003 | 10:52 AM
JV's Avatar
JV
Who?
Please edit that post as the wiring diagram info is not correct...
Here's the correct way to wire it up:
All you need to do is find the Vtec selenoid and pressure switch by the head and distributor. Then you can either run the 2 wires to the ECU or tap them into your exsisting subharness...
Old Mar 16, 2003 | 12:16 PM
JV's Avatar
JV
Who?
Default Re: need help on how to wires vtec on sohc swap (JV)
This will help you too...
Bitcloud
Apr 16, 2017 07:20 AM
db1_jdm
Dec 17, 2007 10:10 PM
Nicaraguense13
11
May 12, 2006 09:49 AM
crxxxxxx
Sep 23, 2004 05:12 PM
hondaacura94
Dec 12, 2003 04:29 PM
