brake pad troubles
dont know if im allowed to post this again in here but heres a link. figured i'd get better response from you guys
https://honda-tech.com/zerothread?id=443458
remove and re-install, maybe you will see what the problem is. I've done this before too, its usually because the rear pads do not line up with the grooves on the caliper piston. Make sure the piston is fully bottomed out too. If that doesnt work, adjust the ebrake.
what do you mean adjust the ebrake? do i need to bleed the brakes, this has gone forma 10 miunte operation to a damm whole day afair and i gotta work today. thanks guys
you can adjust the e-brake under the brake handle in the center console. If the piston is seized in the caliper however you will need to rebuild it, or buy a remanufactured caliper.
crxcess
Oct 9, 2002 10:50 AM
AzianAvenger
Jun 21, 2002 10:21 AM
wickedxbo1
Dec 30, 2001 07:51 PM
